Cesium3DTiles::Schema Struct Referencefinal
An object defining classes and enums. More...
#include <Cesium3DTiles/Schema.h>
Inheritance diagram for Cesium3DTiles::Schema:
std::string id
 Unique identifier for the schema. Schema IDs shall be alphanumeric identifiers matching the regular expression ^[a-zA-Z_][a-zA-Z0-9_]*$.
 The name of the schema, e.g. for display purposes.
 The description of the schema.
std::optional< std::string > version
 Application-specific version of the schema.
std::unordered_map< std::string, Cesium3DTiles::Class > classes
 A dictionary, where each key is a class ID and each value is an object defining the class. Class IDs shall be alphanumeric identifiers matching the regular expression ^[a-zA-Z_][a-zA-Z0-9_]*$.
std::unordered_map< std::string, Cesium3DTiles::Enum > enums
 A dictionary, where each key is an enum ID and each value is an object defining the values for the enum. Enum IDs shall be alphanumeric identifiers matching the regular expression ^[a-zA-Z_][a-zA-Z0-9_]*$.
static constexpr const char * TypeName = "Schema"
Definition at line 18 of file Schema.h.
int64_t Cesium3DTiles::Schema::getSizeBytes ( ) const
Definition at line 65 of file Schema.h.
◆ classes
std::unordered_map<std::string, Cesium3DTiles::Class> Cesium3DTiles::Schema::classes
Definition at line 50 of file Schema.h.
◆ description
std::optional<std::string> Cesium3DTiles::Schema::description
Definition at line 38 of file Schema.h.
◆ enums
std::unordered_map<std::string, Cesium3DTiles::Enum> Cesium3DTiles::Schema::enums
Definition at line 57 of file Schema.h.
◆ id
std::string Cesium3DTiles::Schema::id
Definition at line 28 of file Schema.h.
◆ name
std::optional<std::string> Cesium3DTiles::Schema::name
Definition at line 33 of file Schema.h.
const char* Cesium3DTiles::Schema::TypeName = "Schema"
Definition at line 22 of file Schema.h.
◆ version
std::optional<std::string> Cesium3DTiles::Schema::version
Definition at line 43 of file Schema.h.
