Cesium3DTiles::Tile Struct Referencefinal
A tile in a 3D Tiles tileset. More...
#include <Cesium3DTiles/Tile.h>
Inheritance diagram for Cesium3DTiles::Tile:
Classes
struct  Refine
 Known values for Specifies if additive or replacement refinement is used when traversing the tileset for rendering. This property is required for the root tile of a tileset; it is optional for all other tiles. The default is to inherit from the parent tile. More...
Cesium3DTiles::BoundingVolume boundingVolume
 The bounding volume that encloses the tile.
std::optional< Cesium3DTiles::BoundingVolume > viewerRequestVolume
 Optional bounding volume that defines the volume the viewer shall be inside of before the tile's content will be requested and before the tile will be refined based on geometricError.
double geometricError = double()
 The error, in meters, introduced if this tile is rendered and its children are not. At runtime, the geometric error is used to compute screen space error (SSE), i.e., the error measured in pixels.
std::optional< std::string > refine
std::vector< double > transform
 A floating-point 4x4 affine transformation matrix, stored in column-major order, that transforms the tile's content–i.e., its features as well as content.boundingVolume, boundingVolume, and viewerRequestVolume–from the tile's local coordinate system to the parent tile's coordinate system, or, in the case of a root tile, from the tile's local coordinate system to the tileset's coordinate system. transform does not apply to any volume property when the volume is a region, defined in EPSG:4979 coordinates. transform scales the geometricError by the maximum scaling factor from the matrix.
std::optional< Cesium3DTiles::Content > content
 Metadata about the tile's content and a link to the content. When this is omitted the tile is just used for culling. When this is defined, then contents shall be undefined.
std::vector< Cesium3DTiles::Content > contents
 An array of contents. When this is defined, then content shall be undefined.
std::optional< Cesium3DTiles::MetadataEntity > metadata
 A metadata entity that is associated with this tile.
std::optional< Cesium3DTiles::ImplicitTiling > implicitTiling
 An object that describes the implicit subdivision of this tile.
std::vector< Cesium3DTiles::Tile > children
 An array of objects that define child tiles. Each child tile content is fully enclosed by its parent tile's bounding volume and, generally, has a geometricError less than its parent tile's geometricError. For leaf tiles, there are no children, and this property may not be defined.
static constexpr const char * TypeName = "Tile"
Definition at line 20 of file Tile.h.
int64_t Cesium3DTiles::Tile::getSizeBytes ( ) const
Definition at line 121 of file Tile.h.
◆ boundingVolume
Cesium3DTiles::BoundingVolume Cesium3DTiles::Tile::boundingVolume
Definition at line 43 of file Tile.h.
◆ children
std::vector<Cesium3DTiles::Tile> Cesium3DTiles::Tile::children
Definition at line 113 of file Tile.h.
◆ content
std::optional<Cesium3DTiles::Content> Cesium3DTiles::Tile::content
Definition at line 89 of file Tile.h.
◆ contents
std::vector<Cesium3DTiles::Content> Cesium3DTiles::Tile::contents
Definition at line 95 of file Tile.h.
◆ geometricError
double Cesium3DTiles::Tile::geometricError = double()
Definition at line 57 of file Tile.h.
◆ implicitTiling
std::optional<Cesium3DTiles::ImplicitTiling> Cesium3DTiles::Tile::implicitTiling
Definition at line 105 of file Tile.h.
◆ metadata
std::optional<Cesium3DTiles::MetadataEntity> Cesium3DTiles::Tile::metadata
Definition at line 100 of file Tile.h.
◆ refine
std::optional<std::string> Cesium3DTiles::Tile::refine
Known values are defined in Refine.
Definition at line 68 of file Tile.h.
◆ transform
std::vector<double> Cesium3DTiles::Tile::transform
Initial value:
{1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1}
Definition at line 81 of file Tile.h.
const char* Cesium3DTiles::Tile::TypeName = "Tile"
Definition at line 24 of file Tile.h.
◆ viewerRequestVolume
std::optional<Cesium3DTiles::BoundingVolume> Cesium3DTiles::Tile::viewerRequestVolume
Definition at line 50 of file Tile.h.
