Cesium3DTiles::PropertyStatistics Struct Referencefinal
Statistics about property values. More...
#include <Cesium3DTiles/PropertyStatistics.h>
Inheritance diagram for Cesium3DTiles::PropertyStatistics:
std::optional< CesiumUtility::JsonValue > min
 The minimum property value occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the minimum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::optional< CesiumUtility::JsonValue > max
 The maximum property value occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the maximum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::optional< CesiumUtility::JsonValue > mean
 The arithmetic mean of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the mean of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::optional< CesiumUtility::JsonValue > median
 The median of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the median of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::optional< CesiumUtility::JsonValue > standardDeviation
 The standard deviation of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the standard deviation of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::optional< CesiumUtility::JsonValue > variance
 The variance of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the variance of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::optional< CesiumUtility::JsonValue > sum
 The sum of property values occurring in the tileset. Only applicable to SCALAR, VECN, and MATN types. This is the sum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied.
std::unordered_map< std::string, CesiumUtility::JsonValue > occurrences
 A dictionary, where each key corresponds to an enum name and each value is the number of occurrences of that enum. Only applicable when type is ENUM. For fixed-length arrays, this is an array of component-wise occurrences.
static constexpr const char * TypeName = "PropertyStatistics"
Definition at line 17 of file PropertyStatistics.h.
int64_t Cesium3DTiles::PropertyStatistics::getSizeBytes ( ) const
Definition at line 94 of file PropertyStatistics.h.
◆ max
std::optional<CesiumUtility::JsonValue> Cesium3DTiles::PropertyStatistics::max
Definition at line 38 of file PropertyStatistics.h.
◆ mean
std::optional<CesiumUtility::JsonValue> Cesium3DTiles::PropertyStatistics::mean
Definition at line 46 of file PropertyStatistics.h.
◆ median
std::optional<CesiumUtility::JsonValue> Cesium3DTiles::PropertyStatistics::median
Definition at line 54 of file PropertyStatistics.h.
◆ min
std::optional<CesiumUtility::JsonValue> Cesium3DTiles::PropertyStatistics::min
Definition at line 30 of file PropertyStatistics.h.
◆ occurrences
std::unordered_map<std::string, CesiumUtility::JsonValue> Cesium3DTiles::PropertyStatistics::occurrences
Definition at line 86 of file PropertyStatistics.h.
◆ standardDeviation
std::optional<CesiumUtility::JsonValue> Cesium3DTiles::PropertyStatistics::standardDeviation
Definition at line 62 of file PropertyStatistics.h.
◆ sum
std::optional<CesiumUtility::JsonValue> Cesium3DTiles::PropertyStatistics::sum
Definition at line 78 of file PropertyStatistics.h.
const char* Cesium3DTiles::PropertyStatistics::TypeName = "PropertyStatistics"
Definition at line 22 of file PropertyStatistics.h.
◆ variance
std::optional<CesiumUtility::JsonValue> Cesium3DTiles::PropertyStatistics::variance
Definition at line 70 of file PropertyStatistics.h.
