Statistics about entities. More...
#include <Cesium3DTiles/Statistics.h>
| std::unordered_map< std::string, Cesium3DTiles::ClassStatistics > | classes |
A dictionary, where each key corresponds to a class ID in the classes dictionary of the metatata schema that was defined for the tileset that contains these statistics. Each value is an object containing statistics about entities that conform to the class. | |
| static constexpr const char * | TypeName = "Statistics" |
Definition at line 16 of file Statistics.h.
Definition at line 37 of file Statistics.h.
| std::unordered_map<std::string, Cesium3DTiles::ClassStatistics> Cesium3DTiles::Statistics::classes |
Definition at line 29 of file Statistics.h.
Definition at line 21 of file Statistics.h.
