Cesium3DTiles::Enum Struct Referencefinal
An object defining the values of an enum. More...
#include <Cesium3DTiles/Enum.h>
Inheritance diagram for Cesium3DTiles::Enum:
Classes
struct  ValueType
 Known values for The type of the integer enum value. More...
 The name of the enum, e.g. for display purposes.
 The description of the enum.
std::string valueType = ValueType::UINT16
std::vector< Cesium3DTiles::EnumValue > values
 An array of enum values. Duplicate names or duplicate integer values are not allowed.
static constexpr const char * TypeName = "Enum"
Definition at line 17 of file Enum.h.
int64_t Cesium3DTiles::Enum::getSizeBytes ( ) const
Definition at line 82 of file Enum.h.
◆ description
std::optional<std::string> Cesium3DTiles::Enum::description
Definition at line 60 of file Enum.h.
◆ name
std::optional<std::string> Cesium3DTiles::Enum::name
Definition at line 55 of file Enum.h.
const char* Cesium3DTiles::Enum::TypeName = "Enum"
Definition at line 21 of file Enum.h.
◆ values
std::vector<Cesium3DTiles::EnumValue> Cesium3DTiles::Enum::values
Definition at line 74 of file Enum.h.
◆ valueType
std::string Cesium3DTiles::Enum::valueType = ValueType::UINT16
Known values are defined in ValueType.
Definition at line 68 of file Enum.h.
