A single property of a metadata class. More...
#include <Cesium3DTiles/ClassProperty.h>
Classes | |
| struct | ComponentType |
Known values for The datatype of the element's components. Required for SCALAR, VECN, and MATN types, and disallowed for other types. More... | |
| struct | Type |
| Known values for The element type. More... | |
| The name of the property, e.g. for display purposes. | |
| std::optional< std::string > | description |
| The description of the property. | |
| std::string | type = Type::SCALAR |
| The element type. | |
| std::optional< std::string > | componentType |
The datatype of the element's components. Required for SCALAR, VECN, and MATN types, and disallowed for other types. | |
| std::optional< std::string > | enumType |
Enum ID as declared in the enums dictionary. Required when type is ENUM. Disallowed when type is not ENUM | |
| bool | array = false |
Whether the property is an array. When count is defined the property is a fixed-length array. Otherwise the property is a variable-length array. | |
| std::optional< int64_t > | count |
The number of array elements. May only be defined when array is true. | |
| bool | normalized = false |
Specifies whether integer values are normalized. Only applicable to SCALAR, VECN, and MATN types with integer component types. For unsigned integer component types, values are normalized between [0.0, 1.0]. For signed integer component types, values are normalized between [-1.0, 1.0]. For all other component types, this property shall be false. | |
| std::optional< CesiumUtility::JsonValue > | offset |
An offset to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the component type is FLOAT32 or FLOAT64, or when the property is normalized. Not applicable to variable-length arrays. | |
| std::optional< CesiumUtility::JsonValue > | scale |
A scale to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the component type is FLOAT32 or FLOAT64, or when the property is normalized. Not applicable to variable-length arrays. | |
| std::optional< CesiumUtility::JsonValue > | max |
Maximum allowed value for the property. Only applicable to SCALAR, VECN, and MATN types. This is the maximum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. Not applicable to variable-length arrays. | |
| std::optional< CesiumUtility::JsonValue > | min |
Minimum allowed value for the property. Only applicable to SCALAR, VECN, and MATN types. This is the minimum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. Not applicable to variable-length arrays. | |
| bool | required = false |
If required, the property shall be present in every entity conforming to the class. If not required, individual entities may include noData values, or the entire property may be omitted. As a result, noData has no effect on a required property. Client implementations may use required properties to make performance optimizations. | |
| std::optional< CesiumUtility::JsonValue > | noData |
A noData value represents missing data — also known as a sentinel value — wherever it appears. BOOLEAN properties may not specify noData values. This is given as the plain property value, without the transforms from the normalized, offset, and scale properties. Shall not be defined if required is true. | |
| std::optional< CesiumUtility::JsonValue > | defaultProperty |
A default value to use when encountering a noData value or an omitted property. The value is given in its final form, taking the effect of normalized, offset, and scale properties into account. Shall not be defined if required is true. | |
| std::optional< std::string > | semantic |
| An identifier that describes how this property should be interpreted. The semantic cannot be used by other properties in the class. | |
| static constexpr const char * | TypeName = "ClassProperty" |
Definition at line 17 of file ClassProperty.h.
Definition at line 221 of file ClassProperty.h.
| bool Cesium3DTiles::ClassProperty::array = false |
Definition at line 133 of file ClassProperty.h.
| std::optional<std::string> Cesium3DTiles::ClassProperty::componentType |
Known values are defined in ComponentType.
Definition at line 120 of file ClassProperty.h.
| std::optional<int64_t> Cesium3DTiles::ClassProperty::count |
Definition at line 139 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> Cesium3DTiles::ClassProperty::defaultProperty |
Definition at line 207 of file ClassProperty.h.
| std::optional<std::string> Cesium3DTiles::ClassProperty::description |
Definition at line 103 of file ClassProperty.h.
| std::optional<std::string> Cesium3DTiles::ClassProperty::enumType |
Definition at line 126 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> Cesium3DTiles::ClassProperty::max |
Definition at line 173 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> Cesium3DTiles::ClassProperty::min |
Definition at line 181 of file ClassProperty.h.
| std::optional<std::string> Cesium3DTiles::ClassProperty::name |
Definition at line 98 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> Cesium3DTiles::ClassProperty::noData |
Definition at line 199 of file ClassProperty.h.
| bool Cesium3DTiles::ClassProperty::normalized = false |
Definition at line 149 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> Cesium3DTiles::ClassProperty::offset |
Definition at line 157 of file ClassProperty.h.
| bool Cesium3DTiles::ClassProperty::required = false |
Definition at line 190 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> Cesium3DTiles::ClassProperty::scale |
Definition at line 165 of file ClassProperty.h.
| std::optional<std::string> Cesium3DTiles::ClassProperty::semantic |
Definition at line 213 of file ClassProperty.h.
| std::string Cesium3DTiles::ClassProperty::type = Type::SCALAR |
Definition at line 22 of file ClassProperty.h.
