Cesium3DTiles::BoundingVolume Struct Referencefinal
A bounding volume that encloses a tile or its content. At least one bounding volume property is required. Bounding volumes include box, region, or sphere. More...
#include <Cesium3DTiles/BoundingVolume.h>
Inheritance diagram for Cesium3DTiles::BoundingVolume:
std::vector< double > box
 An array of 12 numbers that define an oriented bounding box. The first three elements define the x, y, and z values for the center of the box. The next three elements (with indices 3, 4, and 5) define the x axis direction and half-length. The next three elements (indices 6, 7, and 8) define the y axis direction and half-length. The last three elements (indices 9, 10, and 11) define the z axis direction and half-length.
std::vector< double > region
 An array of six numbers that define a bounding geographic region in EPSG:4979 coordinates with the order [west, south, east, north, minimum height, maximum height]. Longitudes and latitudes are in radians. The range for latitudes is [-PI/2,PI/2]. The range for longitudes is [-PI,PI]. The value that is given as the 'south' of the region shall not be larger than the value for the 'north' of the region. The heights are in meters above (or below) the WGS84 ellipsoid. The 'minimum height' shall not be larger than the 'maximum height'.
std::vector< double > sphere
 An array of four numbers that define a bounding sphere. The first three elements define the x, y, and z values for the center of the sphere. The last element (with index 3) defines the radius in meters. The radius shall not be negative.
static constexpr const char * TypeName = "BoundingVolume"
Definition at line 16 of file BoundingVolume.h.
int64_t Cesium3DTiles::BoundingVolume::getSizeBytes ( ) const
Definition at line 59 of file BoundingVolume.h.
◆ box
std::vector<double> Cesium3DTiles::BoundingVolume::box
Definition at line 31 of file BoundingVolume.h.
◆ region
std::vector<double> Cesium3DTiles::BoundingVolume::region
Definition at line 43 of file BoundingVolume.h.
◆ sphere
std::vector<double> Cesium3DTiles::BoundingVolume::sphere
Definition at line 51 of file BoundingVolume.h.
const char* Cesium3DTiles::BoundingVolume::TypeName = "BoundingVolume"
Definition at line 21 of file BoundingVolume.h.
