Cesium3DTiles::Class Struct Referencefinal
A class containing a set of properties. More...
#include <Cesium3DTiles/Class.h>
Inheritance diagram for Cesium3DTiles::Class:
 The name of the class, e.g. for display purposes.
 The description of the class.
std::unordered_map< std::string, Cesium3DTiles::ClassProperty > properties
 A dictionary, where each key is a property ID and each value is an object defining the property. Property IDs shall be alphanumeric identifiers matching the regular expression ^[a-zA-Z_][a-zA-Z0-9_]*$.
std::optional< std::string > parent
 Experimental. The parent class ID.
static constexpr const char * TypeName = "Class"
Definition at line 17 of file Class.h.
int64_t Cesium3DTiles::Class::getSizeBytes ( ) const
Definition at line 51 of file Class.h.
◆ description
std::optional<std::string> Cesium3DTiles::Class::description
Definition at line 31 of file Class.h.
◆ name
std::optional<std::string> Cesium3DTiles::Class::name
Definition at line 26 of file Class.h.
◆ parent
std::optional<std::string> Cesium3DTiles::Class::parent
Definition at line 43 of file Class.h.
◆ properties
std::unordered_map<std::string, Cesium3DTiles::ClassProperty> Cesium3DTiles::Class::properties
Definition at line 38 of file Class.h.
const char* Cesium3DTiles::Class::TypeName = "Class"
Definition at line 21 of file Class.h.
