Cesium3DTiles::TilesetSpec Struct Reference
A 3D Tiles tileset. More...
#include <Cesium3DTiles/TilesetSpec.h>
Inheritance diagram for Cesium3DTiles::TilesetSpec:
CesiumUtility::ExtensibleObject Cesium3DTiles::Tileset
Cesium3DTiles::Asset asset
std::unordered_map< std::string, Cesium3DTiles::Properties > properties
 A dictionary object of metadata about per-feature properties.
std::optional< Cesium3DTiles::Schema > schema
 An object defining the structure of metadata classes and enums. When this is defined, then schemaUri shall be undefined.
std::optional< std::string > schemaUri
 The URI (or IRI) of the external schema file. When this is defined, then schema shall be undefined.
std::optional< Cesium3DTiles::Statistics > statistics
 An object containing statistics about metadata entities.
std::vector< Cesium3DTiles::GroupMetadata > groups
 An array of groups that tile content may belong to. Each element of this array is a metadata entity that describes the group. The tile content group property is an index into this array.
std::optional< Cesium3DTiles::MetadataEntity > metadata
 A metadata entity that is associated with this tileset.
double geometricError = double()
 The error, in meters, introduced if this tileset is not rendered. At runtime, the geometric error is used to compute screen space error (SSE), i.e., the error measured in pixels.
Cesium3DTiles::Tile root
 The root tile.
std::vector< std::string > extensionsUsed
 Names of 3D Tiles extensions used somewhere in this tileset.
std::vector< std::string > extensionsRequired
 Names of 3D Tiles extensions required to properly load this tileset. Each element of this array shall also be contained in extensionsUsed.
static constexpr const char * TypeName = "Tileset"
Protected Member Functions
 TilesetSpec ()=default
 This class is not meant to be instantiated directly. Use Tileset instead.
Friends
struct Tileset
A 3D Tiles tileset.
Definition at line 24 of file TilesetSpec.h.
int64_t Cesium3DTiles::TilesetSpec::getSizeBytes ( ) const
Definition at line 98 of file TilesetSpec.h.
◆ Tileset
friend struct Tileset
friend
Definition at line 144 of file TilesetSpec.h.
◆ asset
Cesium3DTiles::Asset Cesium3DTiles::TilesetSpec::asset
Definition at line 33 of file TilesetSpec.h.
◆ extensionsRequired
std::vector<std::string> Cesium3DTiles::TilesetSpec::extensionsRequired
Definition at line 90 of file TilesetSpec.h.
◆ extensionsUsed
std::vector<std::string> Cesium3DTiles::TilesetSpec::extensionsUsed
Definition at line 84 of file TilesetSpec.h.
◆ geometricError
double Cesium3DTiles::TilesetSpec::geometricError = double()
Definition at line 74 of file TilesetSpec.h.
◆ groups
std::vector<Cesium3DTiles::GroupMetadata> Cesium3DTiles::TilesetSpec::groups
Definition at line 62 of file TilesetSpec.h.
◆ metadata
std::optional<Cesium3DTiles::MetadataEntity> Cesium3DTiles::TilesetSpec::metadata
Definition at line 67 of file TilesetSpec.h.
◆ properties
std::unordered_map<std::string, Cesium3DTiles::Properties> Cesium3DTiles::TilesetSpec::properties
Definition at line 38 of file TilesetSpec.h.
◆ root
Cesium3DTiles::Tile Cesium3DTiles::TilesetSpec::root
The root tile.
Definition at line 79 of file TilesetSpec.h.
◆ schema
std::optional<Cesium3DTiles::Schema> Cesium3DTiles::TilesetSpec::schema
Definition at line 44 of file TilesetSpec.h.
◆ schemaUri
std::optional<std::string> Cesium3DTiles::TilesetSpec::schemaUri
Definition at line 50 of file TilesetSpec.h.
◆ statistics
std::optional<Cesium3DTiles::Statistics> Cesium3DTiles::TilesetSpec::statistics
Definition at line 55 of file TilesetSpec.h.
const char* Cesium3DTiles::TilesetSpec::TypeName = "Tileset"
Definition at line 28 of file TilesetSpec.h.
