Statistics about entities that conform to a class that was defined in a metadata schema. More...
#include <Cesium3DTiles/ClassStatistics.h>
| std::optional< int64_t > | count |
| The number of entities that conform to the class. | |
| std::unordered_map< std::string, Cesium3DTiles::PropertyStatistics > | properties |
A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value is an object containing statistics about property values. | |
| static constexpr const char * | TypeName = "ClassStatistics" |
Definition at line 19 of file ClassStatistics.h.
Definition at line 44 of file ClassStatistics.h.
| std::optional<int64_t> Cesium3DTiles::ClassStatistics::count |
Definition at line 29 of file ClassStatistics.h.
| std::unordered_map<std::string, Cesium3DTiles::PropertyStatistics> Cesium3DTiles::ClassStatistics::properties |
Definition at line 36 of file ClassStatistics.h.
Definition at line 24 of file ClassStatistics.h.
