3D Tiles extension for cylinder region bounding volumes. More...
#include <Cesium3DTiles/Extension3dTilesBoundingVolumeCylinder.h>
| double | minRadius = double() |
| The inner radius of the cylinder region along the x and y axes, in meters. | |
| double | maxRadius = double() |
| The outer radius of the cylinder region along the x and y axes, in meters. | |
| double | height = double() |
| The height of the cylinder in meters along the z-axis, in meters. | |
| double | minAngle = -3.14159265359 |
| The minimum angle of the cylinder region in radians. In other words, this is the angle where the cylinder region starts. Must be in the range [-pi, pi]. | |
| double | maxAngle = 3.14159265359 |
| The maximum angle of the cylinder region in radians. In other words, this is the angle where the cylinder region ends. Must be in the range [-pi, pi]. | |
| std::vector< double > | translation = {0, 0, 0} |
| The cylinder's translation along the x, y, and z axes. | |
| std::vector< double > | rotation = {0, 0, 0, 1} |
| The cylinder's rotation, represented by a unit quaternion in the order (x, y, z, w), where w is the scalar. | |
| static constexpr const char * | ExtensionName |
Definition at line 14 of file Extension3dTilesBoundingVolumeCylinder.h.
Definition at line 74 of file Extension3dTilesBoundingVolumeCylinder.h.
Definition at line 23 of file Extension3dTilesBoundingVolumeCylinder.h.
| double Cesium3DTiles::Extension3dTilesBoundingVolumeCylinder::height = double() |
Definition at line 41 of file Extension3dTilesBoundingVolumeCylinder.h.
| double Cesium3DTiles::Extension3dTilesBoundingVolumeCylinder::maxAngle = 3.14159265359 |
Definition at line 55 of file Extension3dTilesBoundingVolumeCylinder.h.
| double Cesium3DTiles::Extension3dTilesBoundingVolumeCylinder::maxRadius = double() |
Definition at line 36 of file Extension3dTilesBoundingVolumeCylinder.h.
| double Cesium3DTiles::Extension3dTilesBoundingVolumeCylinder::minAngle = -3.14159265359 |
Definition at line 48 of file Extension3dTilesBoundingVolumeCylinder.h.
| double Cesium3DTiles::Extension3dTilesBoundingVolumeCylinder::minRadius = double() |
Definition at line 30 of file Extension3dTilesBoundingVolumeCylinder.h.
| std::vector<double> Cesium3DTiles::Extension3dTilesBoundingVolumeCylinder::rotation = {0, 0, 0, 1} |
Definition at line 66 of file Extension3dTilesBoundingVolumeCylinder.h.
| std::vector<double> Cesium3DTiles::Extension3dTilesBoundingVolumeCylinder::translation = {0, 0, 0} |
Definition at line 60 of file Extension3dTilesBoundingVolumeCylinder.h.
Definition at line 19 of file Extension3dTilesBoundingVolumeCylinder.h.
