An object describing the location of subtree files. More...
#include <Cesium3DTiles/Subtrees.h>
| std::string | uri |
A URI with embedded expressions that describes the resource that is associated with an implicit tile in an implicit tileset. Allowed expressions are {level}, {x}, {y}, and {z}. {level} is substituted with the level of the node, {x} is substituted with the x index of the node within the level, and {y} is substituted with the y index of the node within the level. {z} may only be given when the subdivision scheme is OCTREE, and it is substituted with the z index of the node within the level. | |
| static constexpr const char * | TypeName = "Subtrees" |
Definition at line 14 of file Subtrees.h.
Definition at line 32 of file Subtrees.h.
Definition at line 19 of file Subtrees.h.
| std::string Cesium3DTiles::Subtrees::uri |
Definition at line 24 of file Subtrees.h.
