3DTILES_ellipsoid extension data to define the referenced ellipsoid More...
#include <Cesium3DTiles/Extension3dTilesEllipsoid.h>
| std::optional< std::string > | body |
| Name of the body the ellipsoid represents, or 'none'. | |
| std::vector< double > | radii |
| An array of three numbers that define the X, Y and Z radii values in meters for the ellipsoid. | |
| static constexpr const char * | TypeName = "Extension3dTilesEllipsoid" |
| static constexpr const char * | ExtensionName = "3DTILES_ellipsoid" |
Definition at line 16 of file Extension3dTilesEllipsoid.h.
Definition at line 43 of file Extension3dTilesEllipsoid.h.
| std::optional<std::string> Cesium3DTiles::Extension3dTilesEllipsoid::body |
Definition at line 29 of file Extension3dTilesEllipsoid.h.
Definition at line 24 of file Extension3dTilesEllipsoid.h.
| std::vector<double> Cesium3DTiles::Extension3dTilesEllipsoid::radii |
Definition at line 35 of file Extension3dTilesEllipsoid.h.
Definition at line 21 of file Extension3dTilesEllipsoid.h.
