Cesium3DTiles::PropertyTable Struct Referencefinal
Properties conforming to a class, organized as property values stored in binary columnar arrays. More...
#include <Cesium3DTiles/PropertyTable.h>
Inheritance diagram for Cesium3DTiles::PropertyTable:
 The name of the property table, e.g. for display purposes.
std::string classProperty
 The class that property values conform to. The value shall be a class ID declared in the classes dictionary.
int64_t count = int64_t()
 The number of elements in each property array.
std::unordered_map< std::string, Cesium3DTiles::PropertyTableProperty > properties
 A dictionary, where each key corresponds to a property ID in the class' properties dictionary and each value is an object describing where property values are stored. Required properties shall be included in this dictionary.
static constexpr const char * TypeName = "PropertyTable"
Definition at line 19 of file PropertyTable.h.
int64_t Cesium3DTiles::PropertyTable::getSizeBytes ( ) const
Definition at line 57 of file PropertyTable.h.
◆ classProperty
std::string Cesium3DTiles::PropertyTable::classProperty
Definition at line 35 of file PropertyTable.h.
◆ count
int64_t Cesium3DTiles::PropertyTable::count = int64_t()
Definition at line 40 of file PropertyTable.h.
◆ name
std::optional<std::string> Cesium3DTiles::PropertyTable::name
Definition at line 29 of file PropertyTable.h.
◆ properties
std::unordered_map<std::string, Cesium3DTiles::PropertyTableProperty> Cesium3DTiles::PropertyTable::properties
Definition at line 49 of file PropertyTable.h.
const char* Cesium3DTiles::PropertyTable::TypeName = "PropertyTable"
Definition at line 24 of file PropertyTable.h.
