Voxel content type. More...
#include <Cesium3DTiles/ExtensionContent3dTilesContentVoxels.h>
| std::vector< int64_t > | dimensions |
| Dimensions of the voxel grid. x/y/z for a box, r/theta/z for a cylinder, lon/lat/height for an ellipsoid. | |
| std::optional< Cesium3DTiles::Padding > | padding |
| padding | |
| std::string | classProperty |
The class that property values conform to. The value shall be a class ID declared in the classes dictionary. | |
| static constexpr const char * | ExtensionName = "3DTILES_content_voxels" |
Voxel content type.
Definition at line 18 of file ExtensionContent3dTilesContentVoxels.h.
Definition at line 52 of file ExtensionContent3dTilesContentVoxels.h.
| std::string Cesium3DTiles::ExtensionContent3dTilesContentVoxels::classProperty |
Definition at line 44 of file ExtensionContent3dTilesContentVoxels.h.
| std::vector<int64_t> Cesium3DTiles::ExtensionContent3dTilesContentVoxels::dimensions |
Definition at line 33 of file ExtensionContent3dTilesContentVoxels.h.
Definition at line 27 of file ExtensionContent3dTilesContentVoxels.h.
| std::optional<Cesium3DTiles::Padding> Cesium3DTiles::ExtensionContent3dTilesContentVoxels::padding |
padding
Definition at line 38 of file ExtensionContent3dTilesContentVoxels.h.
Definition at line 23 of file ExtensionContent3dTilesContentVoxels.h.
