Cesium3DTiles::BufferSpec Struct Reference
A buffer is a binary blob. It is either the binary chunk of the subtree file, or an external buffer referenced by a URI. More...
#include <Cesium3DTiles/BufferSpec.h>
Inheritance diagram for Cesium3DTiles::BufferSpec:
CesiumUtility::ExtensibleObject Cesium3DTiles::Buffer
std::optional< std::string > uri
 The URI (or IRI) of the file that contains the binary buffer data. Relative paths are relative to the file containing the buffer JSON. uri is required when using the JSON subtree format and not required when using the binary subtree format - when omitted the buffer refers to the binary chunk of the subtree file. Data URIs are not allowed.
int64_t byteLength = int64_t()
 The length of the buffer in bytes.
 The name of the buffer.
static constexpr const char * TypeName = "Buffer"
Protected Member Functions
 BufferSpec ()=default
Friends
struct Buffer
Definition at line 17 of file BufferSpec.h.
int64_t Cesium3DTiles::BufferSpec::getSizeBytes ( ) const
Definition at line 48 of file BufferSpec.h.
◆ Buffer
friend struct Buffer
friend
Definition at line 68 of file BufferSpec.h.
◆ byteLength
int64_t Cesium3DTiles::BufferSpec::byteLength = int64_t()
Definition at line 35 of file BufferSpec.h.
◆ name
std::optional<std::string> Cesium3DTiles::BufferSpec::name
Definition at line 40 of file BufferSpec.h.
const char* Cesium3DTiles::BufferSpec::TypeName = "Buffer"
Definition at line 21 of file BufferSpec.h.
◆ uri
std::optional<std::string> Cesium3DTiles::BufferSpec::uri
Definition at line 30 of file BufferSpec.h.
