Cesium3DTiles::Content Struct Reference
Metadata about the tile's content and a link to the content. More...
#include <Cesium3DTiles/Content.h>
Inheritance diagram for Cesium3DTiles::Content:
CesiumUtility::ExtensibleObject Cesium3DTiles::ConditionalContentItem
std::optional< Cesium3DTiles::BoundingVolume > boundingVolume
 An optional bounding volume that tightly encloses tile content. tile.boundingVolume provides spatial coherence and tile.content.boundingVolume enables tight view frustum culling. When this is omitted, tile.boundingVolume is used.
std::string uri
 A uri that points to tile content. When the uri is relative, it is relative to the referring tileset JSON file.
std::optional< Cesium3DTiles::MetadataEntity > metadata
 Metadata that is associated with this content.
std::optional< int64_t > group
 The group this content belongs to. The value is an index into the array of groups that is defined for the containing tileset.
static constexpr const char * TypeName = "Content"
Definition at line 18 of file Content.h.
int64_t Cesium3DTiles::Content::getSizeBytes ( ) const
Definition at line 55 of file Content.h.
◆ boundingVolume
std::optional<Cesium3DTiles::BoundingVolume> Cesium3DTiles::Content::boundingVolume
Definition at line 30 of file Content.h.
◆ group
std::optional<int64_t> Cesium3DTiles::Content::group
Definition at line 47 of file Content.h.
◆ metadata
std::optional<Cesium3DTiles::MetadataEntity> Cesium3DTiles::Content::metadata
Definition at line 41 of file Content.h.
const char* Cesium3DTiles::Content::TypeName = "Content"
Definition at line 22 of file Content.h.
◆ uri
std::string Cesium3DTiles::Content::uri
Definition at line 36 of file Content.h.
