Cesium3DTiles::EnumValue Struct Referencefinal
An enum value. More...
#include <Cesium3DTiles/EnumValue.h>
Inheritance diagram for Cesium3DTiles::EnumValue:
std::string name
 The name of the enum value.
 The description of the enum value.
int64_t value = int64_t()
 The integer enum value.
static constexpr const char * TypeName = "EnumValue"
An enum value.
Definition at line 16 of file EnumValue.h.
int64_t Cesium3DTiles::EnumValue::getSizeBytes ( ) const
Definition at line 44 of file EnumValue.h.
◆ description
std::optional<std::string> Cesium3DTiles::EnumValue::description
Definition at line 31 of file EnumValue.h.
◆ name
std::string Cesium3DTiles::EnumValue::name
Definition at line 26 of file EnumValue.h.
const char* Cesium3DTiles::EnumValue::TypeName = "EnumValue"
Definition at line 21 of file EnumValue.h.
◆ value
int64_t Cesium3DTiles::EnumValue::value = int64_t()
Definition at line 36 of file EnumValue.h.
