Cesium3DTiles::Asset Struct Referencefinal
Metadata about the entire tileset. More...
#include <Cesium3DTiles/Asset.h>
Inheritance diagram for Cesium3DTiles::Asset:
std::string version
 The 3D Tiles version. The version defines the JSON schema for the tileset JSON and the base set of tile formats.
std::optional< std::string > tilesetVersion
 Application-specific version of this tileset, e.g., for when an existing tileset is updated.
static constexpr const char * TypeName = "Asset"
Definition at line 15 of file Asset.h.
int64_t Cesium3DTiles::Asset::getSizeBytes ( ) const
Definition at line 39 of file Asset.h.
◆ tilesetVersion
std::optional<std::string> Cesium3DTiles::Asset::tilesetVersion
Definition at line 31 of file Asset.h.
const char* Cesium3DTiles::Asset::TypeName = "Asset"
Definition at line 19 of file Asset.h.
◆ version
std::string Cesium3DTiles::Asset::version
Definition at line 25 of file Asset.h.
