CesiumGltf::Material Struct Referencefinal
The material appearance of a primitive. More...
#include <CesiumGltf/Material.h>
Inheritance diagram for CesiumGltf::Material:
Classes
struct  AlphaMode
 Known values for The alpha rendering mode of the material. More...
std::optional< CesiumGltf::MaterialPBRMetallicRoughness > pbrMetallicRoughness
 A set of parameter values that are used to define the metallic-roughness material model from Physically Based Rendering (PBR) methodology. When undefined, all the default values of pbrMetallicRoughness MUST apply.
std::optional< CesiumGltf::MaterialNormalTextureInfo > normalTexture
 The tangent space normal texture.
std::optional< CesiumGltf::MaterialOcclusionTextureInfo > occlusionTexture
 The occlusion texture.
std::optional< CesiumGltf::TextureInfo > emissiveTexture
 The emissive texture.
std::vector< double > emissiveFactor = {0, 0, 0}
 The factors for the emissive color of the material.
std::string alphaMode = AlphaMode::OPAQUE
double alphaCutoff = 0.5
 The alpha cutoff value of the material.
bool doubleSided = false
 Specifies whether the material is double sided.
std::string name
static constexpr const char * TypeName = "Material"
Definition at line 20 of file Material.h.
int64_t CesiumGltf::Material::getSizeBytes ( ) const
Definition at line 135 of file Material.h.
◆ alphaCutoff
double CesiumGltf::Material::alphaCutoff = 0.5
Specifies the cutoff threshold when in MASK alpha mode. If the alpha value is greater than or equal to this value then it is rendered as fully opaque, otherwise, it is rendered as fully transparent. A value greater than 1.0 will render the entire material as fully transparent. This value MUST be ignored for other alpha modes. When alphaMode is not defined, this value MUST NOT be defined.
Definition at line 117 of file Material.h.
◆ alphaMode
std::string CesiumGltf::Material::alphaMode = AlphaMode::OPAQUE
Known values are defined in AlphaMode.
The material's alpha rendering mode enumeration specifying the interpretation of the alpha value of the base color.
Definition at line 105 of file Material.h.
◆ doubleSided
bool CesiumGltf::Material::doubleSided = false
When this value is false, back-face culling is enabled. When this value is true, back-face culling is disabled and double-sided lighting is enabled. The back-face MUST have its normals reversed before the lighting equation is evaluated.
Definition at line 127 of file Material.h.
◆ emissiveFactor
std::vector<double> CesiumGltf::Material::emissiveFactor = {0, 0, 0}
This value defines linear multipliers for the sampled texels of the emissive texture.
Definition at line 94 of file Material.h.
◆ emissiveTexture
std::optional<CesiumGltf::TextureInfo> CesiumGltf::Material::emissiveTexture
It controls the color and intensity of the light being emitted by the material. This texture contains RGB components encoded with the sRGB transfer function. If a fourth component (A) is present, it MUST be ignored. When undefined, the texture MUST be sampled as having 1.0 in RGB components.
Definition at line 86 of file Material.h.
◆ normalTexture
std::optional<CesiumGltf::MaterialNormalTextureInfo> CesiumGltf::Material::normalTexture
The texture encodes RGB components with linear transfer function. Each texel represents the XYZ components of a normal vector in tangent space. The normal vectors use the convention +X is right and +Y is up. +Z points toward the viewer. If a fourth component (A) is present, it MUST be ignored. When undefined, the material does not have a tangent space normal texture.
Definition at line 64 of file Material.h.
◆ occlusionTexture
std::optional<CesiumGltf::MaterialOcclusionTextureInfo> CesiumGltf::Material::occlusionTexture
The occlusion values are linearly sampled from the R channel. Higher values indicate areas that receive full indirect lighting and lower values indicate no indirect lighting. If other channels are present (GBA), they MUST be ignored for occlusion calculations. When undefined, the material does not have an occlusion texture.
Definition at line 75 of file Material.h.
◆ pbrMetallicRoughness
std::optional<CesiumGltf::MaterialPBRMetallicRoughness> CesiumGltf::Material::pbrMetallicRoughness
Definition at line 52 of file Material.h.
const char* CesiumGltf::Material::TypeName = "Material"
Definition at line 24 of file Material.h.
