CesiumUtility::ErrorList Struct Reference
The container to store the error and warning list when loading a tile or glTF content. More...
#include <CesiumUtility/ErrorList.h>
void merge (const ErrorList &errorList)
 Merge the errors and warnings from other ErrorList together.
void merge (ErrorList &&errorList)
template<typename ErrorStr>
void emplaceError (ErrorStr &&error)
 Add an error message.
template<typename WarningStr>
void emplaceWarning (WarningStr &&warning)
 Add a warning message.
bool hasErrors () const noexcept
 Check if there are any error messages.
template<typename PromptStr>
void logError (const std::shared_ptr< spdlog::logger > &pLogger, PromptStr &&prompt) const noexcept
 Log all the error messages.
void logWarning (const std::shared_ptr< spdlog::logger > &pLogger, PromptStr &&prompt) const noexcept
 Log all the warning messages.
void log (const std::shared_ptr< spdlog::logger > &pLogger, PromptStr &&prompt) const noexcept
 Log all the error and warning messages.
std::string format (PromptStr &&prompt) const noexcept
 Format all of the errors and warnings into a single string.
 operator bool () const noexcept
static ErrorList error (std::string errorMessage)
 Creates an ErrorList containing a single error.
static ErrorList warning (std::string warningMessage)
 Creates an ErrorList containing a single warning.
 The error messages of this container.
 The warning messages of this container.
Definition at line 18 of file ErrorList.h.
◆ emplaceError()
void CesiumUtility::ErrorList::emplaceError ( ErrorStr && error)
errorThe error message to be added.
Definition at line 56 of file ErrorList.h.
◆ emplaceWarning()
void CesiumUtility::ErrorList::emplaceWarning ( WarningStr && warning)
warningThe warning message to be added.
Definition at line 65 of file ErrorList.h.
◆ error()
static ErrorList CesiumUtility::ErrorList::error ( std::string errorMessage)
static
errorMessageThe error message.
The new list containing the single error.
◆ format()
std::string CesiumUtility::ErrorList::format ( PromptStr && prompt) const
inlinenoexcept
promptThe message prompt for the messages.
The formatted message, or an empty string if there are no errors or warnings.
Definition at line 141 of file ErrorList.h.
◆ log()
void CesiumUtility::ErrorList::log ( const std::shared_ptr< spdlog::logger > & pLogger,
PromptStr && prompt ) const
inlinenoexcept
pLoggerThe logger to log the messages
Definition at line 120 of file ErrorList.h.
◆ logError()
void CesiumUtility::ErrorList::logError ( const std::shared_ptr< spdlog::logger > & pLogger,
inlinenoexcept
promptThe message prompt for the error messages.
Definition at line 81 of file ErrorList.h.
◆ logWarning()
void CesiumUtility::ErrorList::logWarning ( const std::shared_ptr< spdlog::logger > & pLogger,
inlinenoexcept
promptThe message prompt for the warning messages.
Definition at line 100 of file ErrorList.h.
◆ merge() [1/2]
void CesiumUtility::ErrorList::merge ( const ErrorList & errorList)
errorListThe other instance of ErrorList that will be merged with the current instance.
◆ merge() [2/2]
void CesiumUtility::ErrorList::merge ( ErrorList && errorList)
◆ warning()
static ErrorList CesiumUtility::ErrorList::warning ( std::string warningMessage)
static
warningMessageThe warning message.
The new list containing the single warning.
◆ errors
std::vector<std::string> CesiumUtility::ErrorList::errors
Definition at line 169 of file ErrorList.h.
◆ warnings
std::vector<std::string> CesiumUtility::ErrorList::warnings
Definition at line 174 of file ErrorList.h.
