CesiumGltf::Node Struct Referencefinal
A node in the node hierarchy. When the node contains skin, all mesh.primitives MUST contain JOINTS_0 and WEIGHTS_0 attributes. A node MAY have either a matrix or any combination of translation/rotation/scale (TRS) properties. TRS properties are converted to matrices and postmultiplied in the T * R * S order to compose the transformation matrix; first the scale is applied to the vertices, then the rotation, and then the translation. If none are provided, the transform is the identity. When a node is targeted for animation (referenced by an animation.channel.target), matrix MUST NOT be present. More...
#include <CesiumGltf/Node.h>
Inheritance diagram for CesiumGltf::Node:
std::optional< CesiumGltf::BoundingVolume > boundingVolume
 The bounding volume of the node.
int32_t camera = -1
 The index of the camera referenced by this node.
std::vector< int32_t > children
 The indices of this node's children.
int32_t skin = -1
 The index of the skin referenced by this node.
std::vector< double > matrix = {1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1}
 A floating-point 4x4 transformation matrix stored in column-major order.
int32_t mesh = -1
 The index of the mesh in this node.
int32_t externalAsset = -1
 The index of the external asset in this node. Cannot be used together with mesh.
std::vector< double > rotation = {0, 0, 0, 1}
 The node's unit quaternion rotation in the order (x, y, z, w), where w is the scalar.
std::vector< double > scale = {1, 1, 1}
 The node's non-uniform scale, given as the scaling factors along the x, y, and z axes.
std::vector< double > translation = {0, 0, 0}
 The node's translation along the x, y, and z axes.
std::vector< double > weights
 The weights of the instantiated morph target. The number of array elements MUST match the number of morph targets of the referenced mesh. When defined, mesh MUST also be defined.
std::string name
static constexpr const char * TypeName = "Node"
Definition at line 25 of file Node.h.
int64_t CesiumGltf::Node::getSizeBytes ( ) const
Definition at line 102 of file Node.h.
◆ boundingVolume
std::optional<CesiumGltf::BoundingVolume> CesiumGltf::Node::boundingVolume
Definition at line 34 of file Node.h.
◆ camera
int32_t CesiumGltf::Node::camera = -1
Definition at line 39 of file Node.h.
◆ children
std::vector<int32_t> CesiumGltf::Node::children
Definition at line 44 of file Node.h.
◆ externalAsset
int32_t CesiumGltf::Node::externalAsset = -1
Definition at line 70 of file Node.h.
◆ matrix
std::vector<double> CesiumGltf::Node::matrix = {1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1, 0, 0, 0, 0, 1}
Definition at line 59 of file Node.h.
◆ mesh
int32_t CesiumGltf::Node::mesh = -1
Definition at line 64 of file Node.h.
◆ rotation
std::vector<double> CesiumGltf::Node::rotation = {0, 0, 0, 1}
Definition at line 76 of file Node.h.
◆ scale
std::vector<double> CesiumGltf::Node::scale = {1, 1, 1}
Definition at line 82 of file Node.h.
◆ skin
int32_t CesiumGltf::Node::skin = -1
When a skin is referenced by a node within a scene, all joints used by the skin MUST belong to the same scene. When defined, mesh MUST also be defined.
Definition at line 53 of file Node.h.
◆ translation
std::vector<double> CesiumGltf::Node::translation = {0, 0, 0}
Definition at line 87 of file Node.h.
const char* CesiumGltf::Node::TypeName = "Node"
Definition at line 29 of file Node.h.
◆ weights
std::vector<double> CesiumGltf::Node::weights
Definition at line 94 of file Node.h.
