CesiumGltf::Camera Struct Referencefinal
A camera's projection. A node MAY reference a camera to apply a transform to place the camera in the scene. More...
#include <CesiumGltf/Camera.h>
Inheritance diagram for CesiumGltf::Camera:
Classes
struct  Type
 Known values for Specifies if the camera uses a perspective or orthographic projection. More...
std::optional< CesiumGltf::CameraOrthographic > orthographic
 An orthographic camera containing properties to create an orthographic projection matrix. This property MUST NOT be defined when perspective is defined.
std::optional< CesiumGltf::CameraPerspective > perspective
 A perspective camera containing properties to create a perspective projection matrix. This property MUST NOT be defined when orthographic is defined.
std::string type = Type::perspective
std::string name
static constexpr const char * TypeName = "Camera"
Definition at line 18 of file Camera.h.
int64_t CesiumGltf::Camera::getSizeBytes ( ) const
Definition at line 68 of file Camera.h.
◆ orthographic
std::optional<CesiumGltf::CameraOrthographic> CesiumGltf::Camera::orthographic
Definition at line 41 of file Camera.h.
◆ perspective
std::optional<CesiumGltf::CameraPerspective> CesiumGltf::Camera::perspective
Definition at line 48 of file Camera.h.
◆ type
std::string CesiumGltf::Camera::type = Type::perspective
Based on this, either the camera's perspective or orthographic property MUST be defined.
Definition at line 60 of file Camera.h.
const char* CesiumGltf::Camera::TypeName = "Camera"
Definition at line 22 of file Camera.h.
