CesiumGltf::Asset Struct Referencefinal
Metadata about the glTF asset. More...
#include <CesiumGltf/Asset.h>
Inheritance diagram for CesiumGltf::Asset:
std::optional< std::string > copyright
 A copyright message suitable for display to credit the content creator.
std::optional< std::string > generator
 Tool that generated this glTF model. Useful for debugging.
int32_t thumbnail = -1
 The index of the image in the images array to use as a thumbnail for this asset. The image SHOULD be a common, widely-supported format, but MAY have any media type.
std::string version
 The glTF version in the form of <major>.<minor> that this asset targets.
std::optional< std::string > minVersion
 The minimum glTF version in the form of <major>.<minor> that this asset targets. This property MUST NOT be greater than the asset version.
static constexpr const char * TypeName = "Asset"
Definition at line 16 of file Asset.h.
int64_t CesiumGltf::Asset::getSizeBytes ( ) const
Definition at line 59 of file Asset.h.
◆ copyright
std::optional<std::string> CesiumGltf::Asset::copyright
Definition at line 26 of file Asset.h.
◆ generator
std::optional<std::string> CesiumGltf::Asset::generator
Definition at line 31 of file Asset.h.
◆ minVersion
std::optional<std::string> CesiumGltf::Asset::minVersion
Definition at line 51 of file Asset.h.
◆ thumbnail
int32_t CesiumGltf::Asset::thumbnail = -1
Definition at line 38 of file Asset.h.
const char* CesiumGltf::Asset::TypeName = "Asset"
Definition at line 20 of file Asset.h.
◆ version
std::string CesiumGltf::Asset::version
Definition at line 44 of file Asset.h.
