CesiumGltf::Texture Struct Referencefinal
A texture and its sampler. More...
#include <CesiumGltf/Texture.h>
Inheritance diagram for CesiumGltf::Texture:
int32_t sampler = -1
 The index of the sampler used by this texture. When undefined, a sampler with repeat wrapping and auto filtering SHOULD be used.
int32_t source = -1
 The index of the image used by this texture. When undefined, an extension or other mechanism SHOULD supply an alternate texture source, otherwise behavior is undefined.
std::string name
static constexpr const char * TypeName = "Texture"
Definition at line 14 of file Texture.h.
int64_t CesiumGltf::Texture::getSizeBytes ( ) const
Definition at line 39 of file Texture.h.
◆ sampler
int32_t CesiumGltf::Texture::sampler = -1
Definition at line 24 of file Texture.h.
◆ source
int32_t CesiumGltf::Texture::source = -1
Definition at line 31 of file Texture.h.
const char* CesiumGltf::Texture::TypeName = "Texture"
Definition at line 18 of file Texture.h.
