CesiumGltf::Mesh Struct Referencefinal
A set of primitives to be rendered. Its global transform is defined by a node that references it. More...
#include <CesiumGltf/Mesh.h>
Inheritance diagram for CesiumGltf::Mesh:
std::vector< CesiumGltf::MeshPrimitive > primitives
 An array of primitives, each defining geometry to be rendered.
std::vector< double > weights
 Array of weights to be applied to the morph targets. The number of array elements MUST match the number of morph targets.
std::string name
static constexpr const char * TypeName = "Mesh"
Definition at line 16 of file Mesh.h.
int64_t CesiumGltf::Mesh::getSizeBytes ( ) const
Definition at line 39 of file Mesh.h.
◆ primitives
std::vector<CesiumGltf::MeshPrimitive> CesiumGltf::Mesh::primitives
Definition at line 25 of file Mesh.h.
const char* CesiumGltf::Mesh::TypeName = "Mesh"
Definition at line 20 of file Mesh.h.
◆ weights
std::vector<double> CesiumGltf::Mesh::weights
Definition at line 31 of file Mesh.h.
