CesiumGltf::Sampler Struct Referencefinal
Texture sampler properties for filtering and wrapping modes. More...
#include <CesiumGltf/Sampler.h>
Inheritance diagram for CesiumGltf::Sampler:
Classes
struct  MagFilter
 Known values for Magnification filter. More...
struct  MinFilter
 Known values for Minification filter. More...
struct  WrapS
 Known values for S (U) wrapping mode. More...
struct  WrapT
 Known values for T (V) wrapping mode. More...
std::optional< int32_t > magFilter
std::optional< int32_t > minFilter
int32_t wrapS = WrapS::REPEAT
int32_t wrapT = WrapT::REPEAT
std::string name
static constexpr const char * TypeName = "Sampler"
Definition at line 14 of file Sampler.h.
int64_t CesiumGltf::Sampler::getSizeBytes ( ) const
Definition at line 122 of file Sampler.h.
◆ magFilter
std::optional<int32_t> CesiumGltf::Sampler::magFilter
Known values are defined in MagFilter.
Definition at line 88 of file Sampler.h.
◆ minFilter
std::optional<int32_t> CesiumGltf::Sampler::minFilter
Known values are defined in MinFilter.
Definition at line 96 of file Sampler.h.
const char* CesiumGltf::Sampler::TypeName = "Sampler"
Definition at line 18 of file Sampler.h.
◆ wrapS
int32_t CesiumGltf::Sampler::wrapS = WrapS::REPEAT
Known values are defined in WrapS.
All valid values correspond to WebGL enums.
Definition at line 106 of file Sampler.h.
◆ wrapT
int32_t CesiumGltf::Sampler::wrapT = WrapT::REPEAT
Known values are defined in WrapT.
Definition at line 114 of file Sampler.h.
