CesiumGltf::Skin Struct Referencefinal
Joints and matrices defining a skin. More...
#include <CesiumGltf/Skin.h>
Inheritance diagram for CesiumGltf::Skin:
int32_t inverseBindMatrices = -1
 The index of the accessor containing the floating-point 4x4 inverse-bind matrices.
int32_t skeleton = -1
 The index of the node used as a skeleton root.
std::vector< int32_t > joints
 Indices of skeleton nodes, used as joints in this skin.
std::string name
static constexpr const char * TypeName = "Skin"
Definition at line 15 of file Skin.h.
int64_t CesiumGltf::Skin::getSizeBytes ( ) const
Definition at line 50 of file Skin.h.
◆ inverseBindMatrices
int32_t CesiumGltf::Skin::inverseBindMatrices = -1
Its accessor.count property MUST be greater than or equal to the number of elements of the joints array. When undefined, each matrix is a 4x4 identity matrix.
Definition at line 29 of file Skin.h.
◆ joints
std::vector<int32_t> CesiumGltf::Skin::joints
Definition at line 42 of file Skin.h.
◆ skeleton
int32_t CesiumGltf::Skin::skeleton = -1
The node MUST be the closest common root of the joints hierarchy or a direct or indirect parent node of the closest common root.
Definition at line 37 of file Skin.h.
const char* CesiumGltf::Skin::TypeName = "Skin"
Definition at line 19 of file Skin.h.
