CesiumGltf::Image Struct Referencefinal
This class is not meant to be instantiated directly. Use Image instead. More...
#include <CesiumGltf/Image.h>
Inheritance diagram for CesiumGltf::Image:
CesiumGltf::ImageSpec CesiumGltf::NamedObject CesiumUtility::ExtensibleObject
CesiumUtility::IntrusivePointer< CesiumImage::ImageAsset > pAsset
 The loaded image asset. When an image is loaded from a URL, multiple Image instances may all point to the same CesiumImage::ImageAsset instance.
- Public Attributes inherited from CesiumGltf::ImageSpec
std::optional< std::string > uri
 The URI (or IRI) of the image.
std::optional< std::string > mimeType
 The image's media type. This field MUST be defined when bufferView is defined.
int32_t bufferView = -1
 The index of the bufferView that contains the image. This field MUST NOT be defined when uri is defined.
std::string name
Additional Inherited Members
- Public Member Functions inherited from CesiumGltf::ImageSpec
- Static Public Attributes inherited from CesiumGltf::ImageSpec
static constexpr const char * TypeName = "Image"
- Protected Member Functions inherited from CesiumGltf::ImageSpec
 ImageSpec ()=default
Definition at line 10 of file Image.h.
◆ pAsset
Definition at line 18 of file Image.h.
