CesiumUtility::JsonValue Class Referencefinal
A generic implementation of a value in a JSON structure. More...
#include <CesiumUtility/JsonValue.h>
Public Types
using Null = std::nullptr_t
 The type to represent a null JSON value.
using Bool = bool
 The type to represent a Bool JSON value.
using String = std::string
 The type to represent a String JSON value.
using Object = std::map<std::string, JsonValue>
using Array = std::vector<JsonValue>
 The type to represent an Array JSON value.
 JsonValue () noexcept
 Default constructor.
 JsonValue (std::nullptr_t) noexcept
 Creates a null JSON value.
 JsonValue (double v) noexcept
 Creates a Number JSON value.
 JsonValue (std::int8_t v) noexcept
 Creates a std::int64_t JSON value (Widening conversion from std::int8_t).
 JsonValue (std::uint8_t v) noexcept
 Creates a std::uint64_t JSON value (Widening conversion from std::uint8_t).
 JsonValue (std::int16_t v) noexcept
 Creates a std::int64_t JSON value (Widening conversion from std::int16_t).
 JsonValue (std::uint16_t v) noexcept
 Creates a std::uint64_t JSON value (Widening conversion from std::uint16_t).
 JsonValue (std::int32_t v) noexcept
 Creates a std::int64_t JSON value (Widening conversion from std::int32_t).
 JsonValue (std::uint32_t v) noexcept
 Creates a std::uint64_t JSON value (Widening conversion from std::uint32_t).
 JsonValue (std::int64_t v) noexcept
 Creates a std::int64_t JSON value.
 JsonValue (std::uint64_t v) noexcept
 Creates a std::uint64_t JSON value.
 JsonValue (bool v) noexcept
 Creates a Bool JSON value.
 JsonValue (const std::string &v)
 Creates a String JSON value.
 JsonValue (std::string &&v) noexcept
 JsonValue (const char *v)
 JsonValue (const std::map< std::string, JsonValue > &v)
 Creates an Object JSON value with the given properties.
 JsonValue (std::map< std::string, JsonValue > &&v)
 JsonValue (const std::vector< JsonValue > &v)
 Creates an Array JSON value with the given elements.
 JsonValue (std::vector< JsonValue > &&v) noexcept
 JsonValue (std::initializer_list< JsonValue > v)
 Creates an JSON value from the given initializer list.
 JsonValue (std::initializer_list< std::pair< const std::string, JsonValue > > v)
const JsonValue * getValuePtrForKey (const std::string &key) const
 Attempts to obtain a pointer to a JsonValue for the given key on this object.
const T * getValuePtrForKey (const std::string &key) const
 Gets a typed value corresponding to the given key in the object represented by this instance.
template<typename To, typename std::enable_if< std::is_integral< To >::value||std::is_floating_point< To >::value >::type * = nullptr>
std::optional< To > getSafeNumericalValueForKey (const std::string &key) const
 Converts the numerical value corresponding to the given key to the provided numerical template type.
To getSafeNumericalValueOrDefaultForKey (const std::string &key, To defaultValue) const
bool hasKey (const std::string &key) const
 Determines if this value is an Object and has the given key.
std::optional< To > getSafeNumber () const
 Gets the numerical quantity from the value casted to the To type. This function should be used over getDouble() / getUint64() / getInt64() if you plan on casting that type into another smaller type or different type.
To getSafeNumberOrDefault (To defaultValue) const noexcept
 Gets the numerical quantity from the value casted to the To type or returns defaultValue if unable to do so.
const JsonValue::Object & getObject () const
 Gets the object from the value.
const JsonValue::String & getString () const
 Gets the string from the value.
const JsonValue::Array & getArray () const
 Gets the array from the value.
std::vector< std::string > getArrayOfStrings (const std::string &defaultString) const
 Gets an array of strings from the value.
bool getBool () const
 Gets the bool from the value.
double getDouble () const
 Gets the double from the value.
std::uint64_t getUint64 () const
 Gets the std::uint64_t from the value.
std::int64_t getInt64 () const
 Gets the std::int64_t from the value.
bool getBoolOrDefault (bool defaultValue) const noexcept
 Gets the bool from the value or returns defaultValue.
const JsonValue::String getStringOrDefault (String defaultValue) const
 Gets the string from the value or returns defaultValue.
double getDoubleOrDefault (double defaultValue) const noexcept
 Gets the double from the value or returns defaultValue.
std::uint64_t getUint64OrDefault (std::uint64_t defaultValue) const noexcept
 Gets the uint64_t from the value or returns defaultValue.
std::int64_t getInt64OrDefault (std::int64_t defaultValue) const noexcept
 Gets the int64_t from the value or returns defaultValue.
bool isNull () const noexcept
 Returns whether this value is a null value.
bool isNumber () const noexcept
 Returns whether this value is a double, std::uint64_t or std::int64_t. Use this function in conjunction with getNumber for safely casting to arbitrary types.
bool isBool () const noexcept
 Returns whether this value is a Bool value.
bool isString () const noexcept
 Returns whether this value is a String value.
bool isObject () const noexcept
 Returns whether this value is an Object value.
bool isArray () const noexcept
 Returns whether this value is an Array value.
bool isDouble () const noexcept
 Returns whether this value is a double value.
bool isUint64 () const noexcept
 Returns whether this value is a std::uint64_t value.
bool isInt64 () const noexcept
 Returns whether this value is a std::int64_t value.
bool operator== (const JsonValue &rhs) const noexcept
 Returns true if two values are equal.
int64_t getSizeBytes () const noexcept
 Returns the size in bytes of this JsonValue.
std::variant< Null, double, std::uint64_t, std::int64_t, Bool, String, Object, Array > value
 The actual value.
Instances of this class are used to represent the common extras field of glTF elements that extend the the ExtensibleObject class.
Definition at line 53 of file JsonValue.h.
Member Typedef Documentation
◆ Array
Definition at line 78 of file JsonValue.h.
◆ Bool
Definition at line 63 of file JsonValue.h.
◆ Null
using CesiumUtility::JsonValue::Null = std::nullptr_t
Definition at line 58 of file JsonValue.h.
◆ Object
using CesiumUtility::JsonValue::Object = std::map<std::string, JsonValue>
Definition at line 73 of file JsonValue.h.
◆ String
using CesiumUtility::JsonValue::String = std::string
Definition at line 68 of file JsonValue.h.
◆ JsonValue() [1/21]
CesiumUtility::JsonValue::JsonValue ( )
inlinenoexcept
Definition at line 83 of file JsonValue.h.
◆ JsonValue() [2/21]
CesiumUtility::JsonValue::JsonValue ( std::nullptr_t )
inlinenoexcept
Definition at line 88 of file JsonValue.h.
◆ JsonValue() [3/21]
CesiumUtility::JsonValue::JsonValue ( double v)
inlinenoexcept
NaN and ±Infinity are represented as JsonValue::Null.
Definition at line 95 of file JsonValue.h.
◆ JsonValue() [4/21]
CesiumUtility::JsonValue::JsonValue ( std::int8_t v)
inlinenoexcept
Definition at line 107 of file JsonValue.h.
◆ JsonValue() [5/21]
CesiumUtility::JsonValue::JsonValue ( std::uint8_t v)
inlinenoexcept
Definition at line 113 of file JsonValue.h.
◆ JsonValue() [6/21]
CesiumUtility::JsonValue::JsonValue ( std::int16_t v)
inlinenoexcept
Definition at line 119 of file JsonValue.h.
◆ JsonValue() [7/21]
CesiumUtility::JsonValue::JsonValue ( std::uint16_t v)
inlinenoexcept
Definition at line 125 of file JsonValue.h.
◆ JsonValue() [8/21]
CesiumUtility::JsonValue::JsonValue ( std::int32_t v)
inlinenoexcept
Definition at line 131 of file JsonValue.h.
◆ JsonValue() [9/21]
CesiumUtility::JsonValue::JsonValue ( std::uint32_t v)
inlinenoexcept
Definition at line 137 of file JsonValue.h.
◆ JsonValue() [10/21]
CesiumUtility::JsonValue::JsonValue ( std::int64_t v)
inlinenoexcept
Definition at line 142 of file JsonValue.h.
◆ JsonValue() [11/21]
CesiumUtility::JsonValue::JsonValue ( std::uint64_t v)
inlinenoexcept
Definition at line 147 of file JsonValue.h.
◆ JsonValue() [12/21]
CesiumUtility::JsonValue::JsonValue ( bool v)
inlinenoexcept
Definition at line 152 of file JsonValue.h.
◆ JsonValue() [13/21]
CesiumUtility::JsonValue::JsonValue ( const std::string & v)
Definition at line 157 of file JsonValue.h.
◆ JsonValue() [14/21]
CesiumUtility::JsonValue::JsonValue ( std::string && v)
inlinenoexcept
Definition at line 162 of file JsonValue.h.
◆ JsonValue() [15/21]
CesiumUtility::JsonValue::JsonValue ( const char * v)
Definition at line 167 of file JsonValue.h.
◆ JsonValue() [16/21]
CesiumUtility::JsonValue::JsonValue ( const std::map< std::string, JsonValue > & v)
Definition at line 172 of file JsonValue.h.
◆ JsonValue() [17/21]
CesiumUtility::JsonValue::JsonValue ( std::map< std::string, JsonValue > && v)
Definition at line 177 of file JsonValue.h.
◆ JsonValue() [18/21]
CesiumUtility::JsonValue::JsonValue ( const std::vector< JsonValue > & v)
Definition at line 182 of file JsonValue.h.
◆ JsonValue() [19/21]
CesiumUtility::JsonValue::JsonValue ( std::vector< JsonValue > && v)
inlinenoexcept
Definition at line 187 of file JsonValue.h.
◆ JsonValue() [20/21]
CesiumUtility::JsonValue::JsonValue ( std::initializer_list< JsonValue > v)
Definition at line 192 of file JsonValue.h.
◆ JsonValue() [21/21]
CesiumUtility::JsonValue::JsonValue ( std::initializer_list< std::pair< const std::string, JsonValue > > v)
Definition at line 198 of file JsonValue.h.
◆ getArray()
const JsonValue::Array & CesiumUtility::JsonValue::getArray ( ) const
inlinenodiscard
The array.
Exceptions
std::bad_variant_accessif the underlying type is not a JsonValue::Array
Definition at line 428 of file JsonValue.h.
◆ getArrayOfStrings()
std::vector< std::string > CesiumUtility::JsonValue::getArrayOfStrings ( const std::string & defaultString) const
nodiscard
defaultStringThe default string to include in the array for an element that is not a string.
The array of strings, or an empty array if this value is not an array at all.
◆ getBool()
bool CesiumUtility::JsonValue::getBool ( ) const
inlinenodiscard
The bool.
Exceptions
std::bad_variant_accessif the underlying type is not a JsonValue::Bool
Definition at line 449 of file JsonValue.h.
◆ getBoolOrDefault()
bool CesiumUtility::JsonValue::getBoolOrDefault ( bool defaultValue) const
inlinenodiscardnoexcept
The bool or defaultValue if this->value is not a bool.
Definition at line 486 of file JsonValue.h.
◆ getDouble()
double CesiumUtility::JsonValue::getDouble ( ) const
inlinenodiscard
The double.
Exceptions
std::bad_variant_accessif the underlying type is not a double
Definition at line 458 of file JsonValue.h.
◆ getDoubleOrDefault()
double CesiumUtility::JsonValue::getDoubleOrDefault ( double defaultValue) const
The double or defaultValue if this->value is not a double.
Definition at line 514 of file JsonValue.h.
◆ getInt64()
std::int64_t CesiumUtility::JsonValue::getInt64 ( ) const
inlinenodiscard
The std::int64_t.
Exceptions
std::bad_variant_accessif the underlying type is not a std::int64_t
Definition at line 478 of file JsonValue.h.
◆ getInt64OrDefault()
std::int64_t CesiumUtility::JsonValue::getInt64OrDefault ( std::int64_t defaultValue) const
The int64_t or defaultValue if this->value is not a int64_t.
Definition at line 542 of file JsonValue.h.
◆ getObject()
const JsonValue::Object & CesiumUtility::JsonValue::getObject ( ) const
inlinenodiscard
The object.
Exceptions
std::bad_variant_accessif the underlying type is not a JsonValue::Object
Definition at line 408 of file JsonValue.h.
◆ getSafeNumber()
std::optional< To > CesiumUtility::JsonValue::getSafeNumber ( ) const
inlinenodiscard
The converted type if it is numerical and it can be cast without precision loss; otherwise, std::nullopt.
Definition at line 351 of file JsonValue.h.
◆ getSafeNumberOrDefault()
To CesiumUtility::JsonValue::getSafeNumberOrDefault ( To defaultValue) const
The converted type if it can be cast without precision loss or defaultValue if it cannot be converted safely.
Definition at line 382 of file JsonValue.h.
◆ getSafeNumericalValueForKey()
std::optional< To > CesiumUtility::JsonValue::getSafeNumericalValueForKey ( const std::string & key) const
inlinenodiscard
If this instance is not a JsonValue::Object, the key does not exist in this object, the named value does not have a numerical type, or if the named value cannot be converted from double / std::uint64_t / std::int64_t without precision loss, returns std::nullopt.
Template Parameters
ToThe expected type of the value.
keyThe key for which to retrieve the value from this object.
The converted value, or std::nullopt if it cannot be converted for any of the previously-mentioned reasons.
Remarks
Compilation will fail if type 'To' is not an integral / float / double type.
Definition at line 278 of file JsonValue.h.
◆ getSafeNumericalValueOrDefaultForKey()
To CesiumUtility::JsonValue::getSafeNumericalValueOrDefaultForKey ( const std::string & key,
To defaultValue ) const
inlinenodiscard
If this instance is not a JsonValue::Object, the key does not exist in this object, or the named value does not have a numerical type that can be represented as T without precision loss, then the default value is returned.
Template Parameters
defaultValueThe value that will be returned if a numerical value can't be obtained.
The converted value.
Exceptions
Ifunable to convert the converted value for one of the aforementioned reasons.
Remarks
Definition at line 311 of file JsonValue.h.
int64_t CesiumUtility::JsonValue::getSizeBytes ( ) const
inlinenoexcept
Definition at line 626 of file JsonValue.h.
◆ getString()
const JsonValue::String & CesiumUtility::JsonValue::getString ( ) const
inlinenodiscard
The string.
Exceptions
std::bad_variant_accessif the underlying type is not a JsonValue::String
Definition at line 418 of file JsonValue.h.
◆ getStringOrDefault()
const JsonValue::String CesiumUtility::JsonValue::getStringOrDefault ( String defaultValue) const
inlinenodiscard
The string or defaultValue if this->value is not a string.
Definition at line 500 of file JsonValue.h.
◆ getUint64()
std::uint64_t CesiumUtility::JsonValue::getUint64 ( ) const
inlinenodiscard
The std::uint64_t.
Exceptions
std::bad_variant_accessif the underlying type is not a std::uint64_t
Definition at line 468 of file JsonValue.h.
◆ getUint64OrDefault()
std::uint64_t CesiumUtility::JsonValue::getUint64OrDefault ( std::uint64_t defaultValue) const
The uint64_t or defaultValue if this->value is not a uint64_t.
Definition at line 528 of file JsonValue.h.
◆ getValuePtrForKey() [1/4]
JsonValue * CesiumUtility::JsonValue::getValuePtrForKey ( const std::string & key)
nodiscard
keyThe key to lookup.
A pointer to the JsonValue for the provided key, or nullptr.
◆ getValuePtrForKey() [2/4]
T * CesiumUtility::JsonValue::getValuePtrForKey ( const std::string & key)
If this instance is not a JsonValue::Object, returns nullptr. If the key does not exist in this object, returns nullptr. If the named value does not have the type T, returns nullptr.
Template Parameters
TThe expected type of the value.
A pointer to the requested value, or nullptr if the value cannot be obtained as requested.
Definition at line 252 of file JsonValue.h.
◆ getValuePtrForKey() [3/4]
const JsonValue * CesiumUtility::JsonValue::getValuePtrForKey ( const std::string & key) const
nodiscard
◆ getValuePtrForKey() [4/4]
const T * CesiumUtility::JsonValue::getValuePtrForKey ( const std::string & key) const
Template Parameters
Definition at line 229 of file JsonValue.h.
◆ hasKey()
bool CesiumUtility::JsonValue::hasKey ( const std::string & key) const
inlinenodiscard
keyThe key.
true if this value contains the key. false if it is not an object or does not contain the given key.
Definition at line 329 of file JsonValue.h.
◆ isArray()
bool CesiumUtility::JsonValue::isArray ( ) const
Definition at line 591 of file JsonValue.h.
◆ isBool()
bool CesiumUtility::JsonValue::isBool ( ) const
Definition at line 570 of file JsonValue.h.
◆ isDouble()
bool CesiumUtility::JsonValue::isDouble ( ) const
Definition at line 598 of file JsonValue.h.
◆ isInt64()
bool CesiumUtility::JsonValue::isInt64 ( ) const
Definition at line 612 of file JsonValue.h.
◆ isNull()
bool CesiumUtility::JsonValue::isNull ( ) const
Definition at line 554 of file JsonValue.h.
◆ isNumber()
bool CesiumUtility::JsonValue::isNumber ( ) const
Definition at line 563 of file JsonValue.h.
◆ isObject()
bool CesiumUtility::JsonValue::isObject ( ) const
Definition at line 584 of file JsonValue.h.
◆ isString()
bool CesiumUtility::JsonValue::isString ( ) const
Definition at line 577 of file JsonValue.h.
◆ isUint64()
bool CesiumUtility::JsonValue::isUint64 ( ) const
Definition at line 605 of file JsonValue.h.
◆ operator==()
bool CesiumUtility::JsonValue::operator== ( const JsonValue & rhs) const
inlinenoexcept
Definition at line 619 of file JsonValue.h.
◆ value
std::variant< Null, double, std::uint64_t, std::int64_t, Bool, String, Object, Array> CesiumUtility::JsonValue::value
The actual value.
The type of the value may be queried with the isNull, isDouble, isBool, isString, isObject, isUint64, isInt64, isNumber, and isArray functions.
The actual value may be obtained with the getNumber, getBool, and getString functions for the respective types. For Object values, the properties may be accessed with the getValueForKey functions.
Definition at line 688 of file JsonValue.h.
