The root object for a glTF asset. More...
#include <CesiumGltf/ModelSpec.h>
| std::vector< std::string > | extensionsUsed |
| Names of glTF extensions used in this asset. | |
| std::vector< std::string > | extensionsRequired |
| Names of glTF extensions required to properly load this asset. | |
| std::vector< CesiumGltf::Accessor > | accessors |
| An array of accessors. | |
| std::vector< CesiumGltf::Animation > | animations |
| An array of keyframe animations. | |
| CesiumGltf::Asset | asset |
| Metadata about the glTF asset. | |
| std::vector< CesiumGltf::Buffer > | buffers |
| An array of buffers. | |
| std::vector< CesiumGltf::BufferView > | bufferViews |
| An array of bufferViews. | |
| std::vector< CesiumGltf::Camera > | cameras |
| An array of cameras. | |
| std::vector< CesiumGltf::ExternalAsset > | externalAssets |
| An array of external assets. | |
| std::vector< CesiumGltf::File > | files |
| An array of file references. | |
| std::vector< CesiumGltf::Image > | images |
| An array of images. | |
| std::vector< CesiumGltf::Material > | materials |
| An array of materials. | |
| std::vector< CesiumGltf::Mesh > | meshes |
| An array of meshes. | |
| std::vector< CesiumGltf::Node > | nodes |
| An array of nodes. | |
| std::vector< CesiumGltf::Sampler > | samplers |
| An array of samplers. | |
| int32_t | scene = -1 |
| The index of the default scene. | |
| std::vector< CesiumGltf::Scene > | scenes |
| An array of scenes. | |
| std::vector< CesiumGltf::Shape > | shapes |
| An array of shapes. | |
| std::vector< CesiumGltf::Skin > | skins |
| An array of skins. | |
| std::vector< CesiumGltf::Texture > | textures |
| An array of textures. | |
| static constexpr const char * | TypeName = "Model" |
| ModelSpec ()=default | |
| This class is not meant to be instantiated directly. Use Model instead. | |
Friends | |
| struct | Model |
Definition at line 33 of file ModelSpec.h.
Definition at line 171 of file ModelSpec.h.
friend |
Definition at line 256 of file ModelSpec.h.
| std::vector<CesiumGltf::Accessor> CesiumGltf::ModelSpec::accessors |
An accessor is a typed view into a bufferView.
Definition at line 54 of file ModelSpec.h.
| std::vector<CesiumGltf::Animation> CesiumGltf::ModelSpec::animations |
Definition at line 59 of file ModelSpec.h.
| CesiumGltf::Asset CesiumGltf::ModelSpec::asset |
Definition at line 64 of file ModelSpec.h.
| std::vector<CesiumGltf::Buffer> CesiumGltf::ModelSpec::buffers |
A buffer points to binary geometry, animation, or skins.
Definition at line 71 of file ModelSpec.h.
| std::vector<CesiumGltf::BufferView> CesiumGltf::ModelSpec::bufferViews |
A bufferView is a view into a buffer generally representing a subset of the buffer.
Definition at line 79 of file ModelSpec.h.
| std::vector<CesiumGltf::Camera> CesiumGltf::ModelSpec::cameras |
A camera defines a projection matrix.
Definition at line 86 of file ModelSpec.h.
| std::vector<std::string> CesiumGltf::ModelSpec::extensionsRequired |
Definition at line 47 of file ModelSpec.h.
| std::vector<std::string> CesiumGltf::ModelSpec::extensionsUsed |
Definition at line 42 of file ModelSpec.h.
| std::vector<CesiumGltf::ExternalAsset> CesiumGltf::ModelSpec::externalAssets |
An external asset references a file in the files array and may be instantiated by any node.
Definition at line 94 of file ModelSpec.h.
| std::vector<CesiumGltf::File> CesiumGltf::ModelSpec::files |
A file reference is a pointer to an external file.
Definition at line 101 of file ModelSpec.h.
| std::vector<CesiumGltf::Image> CesiumGltf::ModelSpec::images |
An array of images.
An image defines data used to create a texture.
Definition at line 108 of file ModelSpec.h.
| std::vector<CesiumGltf::Material> CesiumGltf::ModelSpec::materials |
A material defines the appearance of a primitive.
Definition at line 115 of file ModelSpec.h.
| std::vector<CesiumGltf::Mesh> CesiumGltf::ModelSpec::meshes |
An array of meshes.
A mesh is a set of primitives to be rendered.
Definition at line 122 of file ModelSpec.h.
| std::vector<CesiumGltf::Node> CesiumGltf::ModelSpec::nodes |
An array of nodes.
Definition at line 127 of file ModelSpec.h.
| std::vector<CesiumGltf::Sampler> CesiumGltf::ModelSpec::samplers |
A sampler contains properties for texture filtering and wrapping modes.
Definition at line 134 of file ModelSpec.h.
| int32_t CesiumGltf::ModelSpec::scene = -1 |
This property MUST NOT be defined, when scenes is undefined.
Definition at line 141 of file ModelSpec.h.
| std::vector<CesiumGltf::Scene> CesiumGltf::ModelSpec::scenes |
An array of scenes.
Definition at line 146 of file ModelSpec.h.
| std::vector<CesiumGltf::Shape> CesiumGltf::ModelSpec::shapes |
An array of shapes.
Definition at line 151 of file ModelSpec.h.
| std::vector<CesiumGltf::Skin> CesiumGltf::ModelSpec::skins |
An array of skins.
A skin is defined by joints and matrices.
Definition at line 158 of file ModelSpec.h.
| std::vector<CesiumGltf::Texture> CesiumGltf::ModelSpec::textures |
Definition at line 163 of file ModelSpec.h.
Definition at line 37 of file ModelSpec.h.
