CesiumGltf::Accessor Struct Referencefinal
This class is not meant to be instantiated directly. Use Accessor instead. More...
#include <CesiumGltf/Accessor.h>
Inheritance diagram for CesiumGltf::Accessor:
CesiumGltf::AccessorSpec CesiumGltf::NamedObject CesiumUtility::ExtensibleObject
int8_t computeNumberOfComponents () const noexcept
 Computes the number of components for this accessor.
int8_t computeByteSizeOfComponent () const noexcept
 Computes the number of bytes for this accessor's component type.
int64_t computeBytesPerVertex () const noexcept
 Computes the total number of bytes for this accessor in each vertex.
int64_t computeByteStride (const CesiumGltf::Model &model) const noexcept
 Computes this accessor's stride.
- Public Member Functions inherited from CesiumGltf::AccessorSpec
static int8_t computeNumberOfComponents (const std::string &type) noexcept
 Computes the number of components for a given accessor type.
static int8_t computeByteSizeOfComponent (int32_t componentType) noexcept
 Computes the number of bytes for a given accessor component type.
Additional Inherited Members
- Public Attributes inherited from CesiumGltf::AccessorSpec
int32_t bufferView = -1
 The index of the bufferView.
int64_t byteOffset = 0
 The offset relative to the start of the buffer view in bytes.
int32_t componentType = ComponentType::BYTE
 The datatype of the accessor's components.
bool normalized = false
 Specifies whether integer data values are normalized before usage.
int64_t count = int64_t()
 The number of elements referenced by this accessor.
std::string type = Type::SCALAR
 Specifies if the accessor's elements are scalars, vectors, or matrices.
std::vector< double > max
 Maximum value of each component in this accessor.
std::vector< double > min
 Minimum value of each component in this accessor.
std::optional< CesiumGltf::AccessorSparse > sparse
 Sparse storage of elements that deviate from their initialization value.
std::string name
- Static Public Attributes inherited from CesiumGltf::AccessorSpec
static constexpr const char * TypeName = "Accessor"
- Protected Member Functions inherited from CesiumGltf::AccessorSpec
 AccessorSpec ()=default
Definition at line 12 of file Accessor.h.
◆ computeByteSizeOfComponent() [1/2]
int8_t CesiumGltf::Accessor::computeByteSizeOfComponent ( ) const
noexcept
For example if this accessor's Accessor::componentType is CesiumGltf::Accessor::ComponentType::UNSIGNED_SHORT, then the component type is 2 bytes, while if it's CesiumGltf::Accessor::ComponentType::FLOAT then it is 4 bytes.
The number of bytes for this accessor's component type. Returns 0 if this accessor's Accessor::componentType does not have a valid enumeration value.
◆ computeByteSizeOfComponent() [2/2]
static int8_t CesiumGltf::Accessor::computeByteSizeOfComponent ( int32_t componentType)
staticnoexcept
For example CesiumGltf::Accessor::ComponentType::UNSIGNED_SHORT is 2 bytes while CesiumGltf::Accessor::ComponentType::FLOAT is 4 bytes.
componentTypeThe accessor component type.
The number of bytes for the component type. Returns 0 if Accessor::componentType is not a valid enumeration value.
◆ computeBytesPerVertex()
int64_t CesiumGltf::Accessor::computeBytesPerVertex ( ) const
noexcept
This is computed by multiplying Accessor::computeByteSizeOfComponent by Accessor::computeNumberOfComponents.
The total number of bytes for this accessor in each vertex. Returns 0 if this accessor's Accessor::type or Accessor::componentType does not have a valid enumeration value.
◆ computeByteStride()
int64_t CesiumGltf::Accessor::computeByteStride ( const CesiumGltf::Model & model) const
noexcept
The stride is the number of bytes between the same elements of successive vertices. The returned value will be at least as large as Accessor::computeBytesPerVertex, but maybe be larger if this accessor's data is interleaved with other accessors.
The behavior is undefined if this accessor is not part of the given model.
modelThe model that this accessor is a part of.
The stride in bytes. Returns 0 if this accessor's Accessor::type or Accessor::componentType does not have a valid enumeration value, or if Accessor::bufferView does not refer to a valid BufferView.
◆ computeNumberOfComponents() [1/2]
int8_t CesiumGltf::Accessor::computeNumberOfComponents ( ) const
noexcept
For example if this accessor's Accessor::type is CesiumGltf::Accessor::Type::SCALAR, then it has 1 component, while if it's CesiumGltf::Accessor::Type::VEC4 it has 4 components.
The number of components in this accessor. Returns 0 if this accessor's Accessor::type does not have a valid enumeration value.
◆ computeNumberOfComponents() [2/2]
static int8_t CesiumGltf::Accessor::computeNumberOfComponents ( const std::string & type)
staticnoexcept
For example CesiumGltf::Accessor::Type::SCALAR has 1 component while CesiumGltf::Accessor::Type::VEC4 has 4 components.
typeThe accessor type.
The number of components. Returns 0 if Accessor::type is not a valid enumeration value.
