CesiumGltf::MeshPrimitive Struct Referencefinal
Geometry to be rendered with the given material. More...
#include <CesiumGltf/MeshPrimitive.h>
Inheritance diagram for CesiumGltf::MeshPrimitive:
Classes
struct  Mode
 Known values for The topology type of primitives to render. More...
std::unordered_map< std::string, int32_t > attributes
 A plain JSON object, where each key corresponds to a mesh attribute semantic and each value is the index of the accessor containing attribute's data.
int32_t indices = -1
 The index of the accessor that contains the vertex indices.
int32_t material = -1
 The index of the material to apply to this primitive when rendering.
int32_t mode = Mode::TRIANGLES
std::vector< std::unordered_map< std::string, int32_t > > targets
 An array of morph targets.
static constexpr const char * TypeName = "MeshPrimitive"
Definition at line 17 of file MeshPrimitive.h.
int64_t CesiumGltf::MeshPrimitive::getSizeBytes ( ) const
Definition at line 90 of file MeshPrimitive.h.
◆ attributes
std::unordered_map<std::string, int32_t> CesiumGltf::MeshPrimitive::attributes
Definition at line 55 of file MeshPrimitive.h.
◆ indices
int32_t CesiumGltf::MeshPrimitive::indices = -1
When this is undefined, the primitive defines non-indexed geometry. When defined, the accessor MUST have SCALAR type and an unsigned integer component type.
Definition at line 64 of file MeshPrimitive.h.
◆ material
int32_t CesiumGltf::MeshPrimitive::material = -1
Definition at line 69 of file MeshPrimitive.h.
◆ mode
int32_t CesiumGltf::MeshPrimitive::mode = Mode::TRIANGLES
Known values are defined in Mode.
Definition at line 77 of file MeshPrimitive.h.
◆ targets
std::vector<std::unordered_map<std::string, int32_t> > CesiumGltf::MeshPrimitive::targets
Definition at line 82 of file MeshPrimitive.h.
const char* CesiumGltf::MeshPrimitive::TypeName = "MeshPrimitive"
Definition at line 22 of file MeshPrimitive.h.
