CesiumGltf::Scene Struct Referencefinal
The root nodes of a scene. More...
#include <CesiumGltf/Scene.h>
Inheritance diagram for CesiumGltf::Scene:
std::vector< int32_t > nodes
 The indices of each root node.
std::string name
static constexpr const char * TypeName = "Scene"
Definition at line 15 of file Scene.h.
int64_t CesiumGltf::Scene::getSizeBytes ( ) const
Definition at line 32 of file Scene.h.
◆ nodes
std::vector<int32_t> CesiumGltf::Scene::nodes
Definition at line 24 of file Scene.h.
const char* CesiumGltf::Scene::TypeName = "Scene"
Definition at line 19 of file Scene.h.
