CesiumGltf::Buffer Struct Referencefinal
This class is not meant to be instantiated directly. Use Buffer instead. More...
#include <CesiumGltf/Buffer.h>
Inheritance diagram for CesiumGltf::Buffer:
CesiumGltf::BufferSpec CesiumGltf::NamedObject CesiumUtility::ExtensibleObject
BufferCesium cesium
 Holds properties that are specific to the glTF loader rather than part of the glTF spec.
- Public Attributes inherited from CesiumGltf::BufferSpec
int32_t chunk = -1
 The index of the chunk that contains the buffer data.
std::optional< std::string > uri
 The URI (or IRI) of the buffer.
int64_t byteLength = int64_t()
 The length of the buffer in bytes.
std::string name
Additional Inherited Members
- Public Member Functions inherited from CesiumGltf::BufferSpec
- Static Public Attributes inherited from CesiumGltf::BufferSpec
static constexpr const char * TypeName = "Buffer"
- Protected Member Functions inherited from CesiumGltf::BufferSpec
 BufferSpec ()=default
Definition at line 9 of file Buffer.h.
◆ cesium
BufferCesium CesiumGltf::Buffer::cesium
Definition at line 16 of file Buffer.h.
