A keyframe animation. More...
#include <CesiumGltf/Animation.h>
Public Member Functions inherited from CesiumGltf::NamedObject | |
| Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. Calling this method may be slow as it requires traversing the object's entire structure. | |
| std::vector< CesiumGltf::AnimationChannel > | channels |
| An array of animation channels. An animation channel combines an animation sampler with a target property being animated. Different channels of the same animation MUST NOT have the same targets. | |
| std::vector< CesiumGltf::AnimationSampler > | samplers |
| An array of animation samplers. An animation sampler combines timestamps with a sequence of output values and defines an interpolation algorithm. | |
Public Attributes inherited from CesiumGltf::NamedObject | |
| std::string | name |
| The user-defined name of this object. | |
| static constexpr const char * | TypeName = "Animation" |
Definition at line 16 of file Animation.h.
Definition at line 42 of file Animation.h.
| std::vector<CesiumGltf::AnimationChannel> CesiumGltf::Animation::channels |
Definition at line 27 of file Animation.h.
| std::vector<CesiumGltf::AnimationSampler> CesiumGltf::Animation::samplers |
Definition at line 34 of file Animation.h.
Definition at line 20 of file Animation.h.
