CesiumGltf::BufferView Struct Referencefinal
A view into a buffer generally representing a subset of the buffer. More...
#include <CesiumGltf/BufferView.h>
Inheritance diagram for CesiumGltf::BufferView:
Classes
struct  Target
 Known values for The hint representing the intended GPU buffer type to use with this buffer view. More...
int32_t buffer = -1
 The index of the buffer.
int64_t byteOffset = 0
 The offset into the buffer in bytes.
int64_t byteLength = int64_t()
 The length of the bufferView in bytes.
std::optional< int64_t > byteStride
 The stride, in bytes.
std::optional< int32_t > target
std::string name
static constexpr const char * TypeName = "BufferView"
Definition at line 15 of file BufferView.h.
int64_t CesiumGltf::BufferView::getSizeBytes ( ) const
Definition at line 72 of file BufferView.h.
◆ buffer
int32_t CesiumGltf::BufferView::buffer = -1
Definition at line 36 of file BufferView.h.
◆ byteLength
int64_t CesiumGltf::BufferView::byteLength = int64_t()
Definition at line 46 of file BufferView.h.
◆ byteOffset
int64_t CesiumGltf::BufferView::byteOffset = 0
Definition at line 41 of file BufferView.h.
◆ byteStride
std::optional<int64_t> CesiumGltf::BufferView::byteStride
The stride, in bytes, between vertex attributes. When this is not defined, data is tightly packed. When two or more accessors use the same buffer view, this field MUST be defined.
Definition at line 55 of file BufferView.h.
◆ target
std::optional<int32_t> CesiumGltf::BufferView::target
Known values are defined in Target.
Definition at line 64 of file BufferView.h.
const char* CesiumGltf::BufferView::TypeName = "BufferView"
Definition at line 19 of file BufferView.h.
