CesiumUtility Namespace Reference
Utility classes for Cesium. More...
Classes
class  AttributeCompression
 Functions to handle compressed attributes in different formats. More...
struct  Color
 Represents an RGBA color value. More...
struct  Credit
 Represents an HTML string that should be shown on screen to attribute third parties for used data, imagery, etc. Acts as a handle into a CreditSystem object that actually holds the credit string. More...
class  CreditReferencer
 Provides a way to reference a set of credits in a CreditSystem so that the references can easily be released later. More...
class  CreditSource
 Represents a source of credits, such as a tileset or raster overlay, provided to a CreditSystem. More...
struct  CreditsSnapshot
 A snapshot of the credits currently active in a CreditSystem. More...
class  CreditSystem
 Creates and manages Credit objects. Avoids repetitions and tracks which credits should be shown and which credits should be removed this frame. More...
class  DerivedValue
 A function object that caches the last result of a derivation function based on its input. This is sometimes called "memoization", but this simple implementation only remembers the result of a single past invocation. More...
class  DoublyLinkedListAdvanced
 A doubly-linked list. More...
class  DoublyLinkedListPointers
 Contains the previous and next pointers for an element in a DoublyLinkedList. More...
struct  ErrorList
 The container to store the error and warning list when loading a tile or glTF content. More...
struct  ExtensibleObject
 The base class for objects that have extensions and extras. More...
struct  Hash
 Contains functions for working with hashes. More...
class  IDepotOwningAsset
 An interface representing the depot that owns a SharedAsset. This interface is an implementation detail of the shared asset system and should not be used directly. More...
class  IntrusivePointer
 A smart pointer that calls addReference and releaseReference on the controlled object. More...
class  JsonHelpers
 A collection of helper functions to make reading JSON simpler. More...
class  JsonValue
 A generic implementation of a value in a JSON structure. More...
class  Math
 Mathematical constants and functions. More...
class  ReferenceCounted
 A reference-counted base class, meant to be used with IntrusivePointer. More...
struct  Result
 Holds the result of an operation. If the operation succeeds, it will provide a value. It may also provide errors and warnings. More...
struct  Result< CesiumUtility::IntrusivePointer< T > >
class  ScopeGuard
 A utility that will automatically call the lambda function when exiting a scope. More...
class  SharedAsset
 An asset that is potentially shared between multiple objects, such as an image shared between multiple glTF models. This is intended to be the base class for such assets. More...
class  StringHelpers
 Helper functions for working with strings. More...
class  TransformIterator
 An iterator that wraps another iterator and applies a transformation function to each element as it is accessed. More...
class  TreeTraversalState
 Associates state (arbitrary data) with each node during partial, depth-first traversal of a tree. Then, during a later traversal of a potentially different subset of the same tree, the state previously associated with each node can be looked up. More...
class  Uri
 A class for parsing and manipulating Uniform Resource Identifiers (URIs). More...
class  UriQuery
 A class for parsing and manipulating the query string of a URI. More...
Typedefs
template<typename T, DoublyLinkedListPointers< T >T::* Pointers>
using DoublyLinkedList = DoublyLinkedListAdvanced<T, T, Pointers>
 An intrusive doubly-linked list.
using ReferenceCountedThreadSafe = ReferenceCounted<T, true>
 A reference-counted base class, meant to be used with IntrusivePointer. The reference count is thread-safe, so references may be added and removed from any thread at any time. The object will be destroyed in the thread that releases the last reference.
using ReferenceCountedNonThreadSafe = ReferenceCounted<T, false>
 A reference-counted base class, meant to be used with IntrusivePointer. The reference count is not thread-safe, so references must be added and removed (including automatically via IntrusivePointer) from only one thread at a time.
using ResultPointer = Result<IntrusivePointer<T>>
 A convenient shortcut for CesiumUtility::Result<CesiumUtility::IntrusivePointer<T>>.
Enumerations
enum class  CreditFilteringMode : uint8_t { None = 0 , UniqueHtmlAndShowOnScreen = 1 , UniqueHtml = 2 }
 Specifies how credit system snapshots should handle multiple credits with the same HTML string. More...
Functions
template<typename TInput, typename TDerivation>
auto makeDerivedValue (TDerivation &&derivation) -> DerivedValue< TInput, std::decay_t< TDerivation > >
 Helper factory to construct a DerivedValue while specifying only the input type explicitly and letting the callable type (TDerivation) be deduced.
bool isGzip (const std::span< const std::byte > &data)
 Checks whether the data is gzipped.
bool gzip (const std::span< const std::byte > &data, std::vector< std::byte > &out)
 Gzips data.
bool gunzip (const std::span< const std::byte > &data, std::vector< std::byte > &out)
 Gunzips data.
template<typename T, typename U>
IntrusivePointer< T > const_intrusive_cast (const IntrusivePointer< U > &p) noexcept
 Casts a const IntrusivePointer to its non-const equivalent.
template<class TIterator>
std::string joinToString (TIterator begin, TIterator end, const std::string &separator)
 Joins multiple elements together into a string, separated by a given separator.
template<class TCollection>
std::string joinToString (const TCollection &collection, const std::string &separator)
template<typename TTo, typename TFrom>
std::optional< TTo > losslessNarrow (TFrom from) noexcept
 Attempts a narrowing conversion of TFrom into TTo without losing information. If a lossless conversion can't be performed, std::nullopt is returned.
constexpr TTo losslessNarrowOrDefault (TFrom from, TTo defaultValue) noexcept
 Attempts a narrowing conversion of TFrom into TTo without losing information. If a lossless conversion can't be performed, defaultValue is returned.
template<typename ExitFunction>
 ScopeGuard (ExitFunction) -> ScopeGuard< ExitFunction >
 Template deduction guide for ScopeGuard to help the compiler figure out that the type of ExitFunction should be the type of the function passed to the constructor.
template<typename To, typename From>
std::span< To > reintepretCastSpan (const std::span< From > &from) noexcept
 This function converts between span types. This function has the same rules with C++ reintepret_cast https://en.cppreference.com/w/cpp/language/reinterpret_cast. So please use it carefully.
template<typename Tuple, typename Func>
auto transformTuple (Tuple &&tuple, Func &&f)
 Transforms each element of a tuple by applying a function to it.
--- comment: This file was generated by dep-graph-gen. DO NOT EDIT THIS FILE! title: CesiumUtility Dependency Graph --- graph TD classDef dependencyNode fill:#fff,stroke:#ccc,color:#666,font-weight:bold,font-size:28px classDef libraryNode fill:#9f9,font-weight:bold,font-size:28px CesiumUtility[CesiumUtility] --> ada_ada{{ada::ada}} CesiumUtility[CesiumUtility] --> glm_glm{{glm::glm}} CesiumUtility[CesiumUtility] --> spdlog_spdlog{{spdlog::spdlog}} CesiumUtility[CesiumUtility] --> zlib-ng_zlib{{zlib-ng::zlib}} class ada_ada,glm_glm,spdlog_spdlog,zlib-ng_zlib dependencyNode class CesiumUtility libraryNode
Typedef Documentation
◆ DoublyLinkedList
using CesiumUtility::DoublyLinkedList = DoublyLinkedListAdvanced<T, T, Pointers>
Definition at line 272 of file DoublyLinkedList.h.
◆ ReferenceCountedNonThreadSafe
using CesiumUtility::ReferenceCountedNonThreadSafe = ReferenceCounted<T, false>
Template Parameters
TThe type that is deriving from this class. For example, you should declare your class as class MyClass : public ReferenceCountedNonThreadSafe<MyClass> { ... };
Definition at line 136 of file ReferenceCounted.h.
◆ ReferenceCountedThreadSafe
using CesiumUtility::ReferenceCountedThreadSafe = ReferenceCounted<T, true>
Template Parameters
TThe type that is deriving from this class. For example, you should declare your class as class MyClass : public ReferenceCountedThreadSafe<MyClass> { ... };
Definition at line 123 of file ReferenceCounted.h.
◆ ResultPointer
using CesiumUtility::ResultPointer = Result<IntrusivePointer<T>>
Template Parameters
TThe type of object that the IntrusivePointer points to.
Definition at line 122 of file Result.h.
◆ CreditFilteringMode
enum class CesiumUtility::CreditFilteringMode : uint8_t
strong
Enumerator
None
No filtering is performed. Each unique Credit is reported.
Credits are filtered so that each reported credit has a combination of HTML string and CreditSystem::shouldBeShownOnScreen value that is unique from all the other reported credits.
If multiple credits have the same HTML string but different CreditSystem::shouldBeShownOnScreen values, they will be reported as separate credits.
It is unspecified which of the multiple credits with the same properties will be reported.
UniqueHtml
Credits with identical HTML strings are reported as one Credit even if they have a different CreditSource or CreditSystem::shouldBeShownOnScreen value.
It is unspecified which of the multiple credits with the same source will be reported. However, it is guaranteed that if any of the multiple credits has CreditSystem::shouldBeShownOnScreen set to true, the reported credit will also have it set to true.
Definition at line 21 of file CreditSystem.h.
Function Documentation
◆ const_intrusive_cast()
IntrusivePointer< T > CesiumUtility::const_intrusive_cast ( const IntrusivePointer< U > & p)
noexcept
pThe const IntrusivePointer.
A non-const IntrusivePointer with the same underlying pointer.
Definition at line 269 of file IntrusivePointer.h.
◆ gunzip()
bool CesiumUtility::gunzip ( const std::span< const std::byte > & data,
std::vector< std::byte > & out )
Gunzips data.
If successful, it will return true and the result will be in the provided vector.
dataThe data to gunzip.
outThe gunzipped data.
True if successful, false otherwise.
◆ gzip()
bool CesiumUtility::gzip ( const std::span< const std::byte > & data,
Gzips data.
dataThe data to gzip.
outThe gzipped data.
◆ isGzip()
bool CesiumUtility::isGzip ( const std::span< const std::byte > & data)
dataThe data.
Whether the data is gzipped
◆ joinToString() [1/2]
std::string CesiumUtility::joinToString ( const TCollection & collection,
const std::string & separator )
Template Parameters
TIteratorThe type of the collection iterator.
collectionThe collection of elements to be joined.
separatorThe string to use to separate successive elements.
The joined string.
Definition at line 45 of file joinToString.h.
◆ joinToString() [2/2]
std::string CesiumUtility::joinToString ( TIterator begin,
TIterator end,
Template Parameters
beginAn iterator referring to the first element to join.
endAn iterator referring to one past the last element to join.
The joined string.
Definition at line 19 of file joinToString.h.
◆ losslessNarrow()
std::optional< TTo > CesiumUtility::losslessNarrow ( TFrom from)
externnoexcept
Template Parameters
TToThe type to convert to.
TFromThe type to convert from.
fromThe value to perform the conversion on.
◆ losslessNarrowOrDefault()
TTo CesiumUtility::losslessNarrowOrDefault ( TFrom from,
TTo defaultValue )
constexprnoexcept
Template Parameters
defaultValueThe value that will be returned if a lossless conversion can't be performed.
Definition at line 43 of file JsonValue.h.
◆ makeDerivedValue()
auto CesiumUtility::makeDerivedValue ( TDerivation && derivation) -> DerivedValue<TInput, std::decay_t<TDerivation>>
Definition at line 79 of file DerivedValue.h.
◆ reintepretCastSpan()
std::span< To > CesiumUtility::reintepretCastSpan ( const std::span< From > & from)
noexcept
Definition at line 13 of file SpanHelper.h.
◆ transformTuple()
auto CesiumUtility::transformTuple ( Tuple && tuple,
Func && f )
The function is guaranteed to be applied to each element in order.
Template Parameters
TupleThe tuple to transform.
FuncThe function to apply to each element.
tupleThe tuple whose elements are to be transformed.
fThe function to apply to each element.
A new tuple with each element transformed by the given function.
Definition at line 30 of file transformTuple.h.
