CesiumUtility::UriQuery Class Referencefinal
A class for parsing and manipulating the query string of a URI. More...
#include <CesiumUtility/Uri.h>
 UriQuery (const std::string_view &queryString)
 Creates a UriQuery object from a query string.
 UriQuery (const Uri &uri)
 Creates a UriQuery object from a Uri instance.
 UriQuery ()=default
 Creates an empty UriQuery object.
std::optional< std::string_view > getValue (const std::string &key)
 Obtains the value of the given key from the query parameters, if possible.
void setValue (const std::string &key, const std::string &value)
 Sets the given key in the query parameters to the given value. If the key doesn't exist already, it will be added to the query parameters. Otherwise, the previous value will be overwritten.
bool hasValue (const std::string &key)
 Returns true if this query string contains a value for the given key, or false otherwise.
std::string toQueryString () const
 Converts this object back into a query string, including all modifications that have been made. This result can be passed directly to Uri::setQuery.
auto begin () const
 Returns an iterator pointing to the beginning of the query parameters.
auto end () const
 Returns an iterator pointing to the end of the query parameters.
auto front () const
 Returns the first element in the query parameters.
auto back () const
 Returns the last element in the query parameters.
Definition at line 373 of file Uri.h.
◆ UriQuery() [1/2]
CesiumUtility::UriQuery::UriQuery ( const std::string_view & queryString)
This query string should be in the format key1=value1&key2=value2&key3=value3.... This is the format returned by Uri::getQuery. This string can include percent-encoded values.
queryStringThe query string to parse into a query params object.
Definition at line 384 of file Uri.h.
◆ UriQuery() [2/2]
CesiumUtility::UriQuery::UriQuery ( const Uri & uri)
This is equivalent to UriQuery(uri.getQuery()).
uriThe URI instance to obtain the query params from.
Definition at line 392 of file Uri.h.
◆ back()
auto CesiumUtility::UriQuery::back ( ) const
Definition at line 449 of file Uri.h.
◆ begin()
auto CesiumUtility::UriQuery::begin ( ) const
Definition at line 443 of file Uri.h.
◆ end()
auto CesiumUtility::UriQuery::end ( ) const
Definition at line 445 of file Uri.h.
◆ front()
auto CesiumUtility::UriQuery::front ( ) const
Definition at line 447 of file Uri.h.
◆ getValue()
std::optional< std::string_view > CesiumUtility::UriQuery::getValue ( const std::string & key)
If the URI can't be parsed, or the key doesn't exist in the query string, std::nullopt will be returned.
keyThe key whose value will be obtained from the query string, if possible.
The value of the given key in the query string, or std::nullopt if not found.
Definition at line 410 of file Uri.h.
◆ hasValue()
bool CesiumUtility::UriQuery::hasValue ( const std::string & key)
keyThe key to check.
Definition at line 432 of file Uri.h.
◆ setValue()
void CesiumUtility::UriQuery::setValue ( const std::string & key,
const std::string & value )
keyThe key to be added to the query string.
valueThe value to be added to the query string.
Definition at line 422 of file Uri.h.
◆ toQueryString()
std::string CesiumUtility::UriQuery::toQueryString ( ) const
Definition at line 439 of file Uri.h.
