A doubly-linked list. More...
#include <CesiumUtility/DoublyLinkedList.h>
| void | remove (T &node) noexcept |
| Removes the given node from this list. | |
| void | insertAfter (T &after, T &node) noexcept |
| Insert the given node after the other node. | |
| void | insertBefore (T &before, T &node) noexcept |
| Insert the given node before the other node. | |
| void | insertAtHead (T &node) noexcept |
| Insert the given node as the new head of the list. | |
| void | insertAtTail (T &node) noexcept |
| Insert the given node as the new tail of the list. | |
| size_t | size () const noexcept |
| Returns the size of this list. | |
| T * | head () noexcept |
Returns the head node of this list, or nullptr if the list is empty. | |
| const T * | head () const noexcept |
| T * | tail () noexcept |
Returns the tail node of this list, or nullptr if the list is empty. | |
| const T * | tail () const noexcept |
| T * | next (T &node) noexcept |
Returns the next node after the given one, or nullptr if the given node is the tail. | |
| const T * | next (const T &node) const noexcept |
| T * | next (T *pNode) noexcept |
Returns the next node after the given one, or the head if the given node is nullptr. | |
| const T * | next (const T *pNode) const noexcept |
| T * | previous (T &node) noexcept |
Returns the previous node before the given one, or nullptr if the given node is the head. | |
| const T * | previous (const T &node) const noexcept |
| T * | previous (T *pNode) |
Returns the previous node before the given one, or the tail if the given node is nullptr. | |
| const T * | previous (const T *pNode) const noexcept |
| bool | contains (const T &node) const |
| Determines if this list contains a given node in constant time. In order to avoid a full list scan, this method assumes that if the node has any next or previous node, then it is contained in this list. Do not use this method to determine which of multiple lists contain this node. | |
In this implementation, the previous and next pointers are embedded directly in the data object.
| T | The data object type. |
| (T::*Pointers) | A member pointer to the field that holds the links to the previous and next nodes. |
Definition at line 63 of file DoublyLinkedList.h.
| node | The node to check. |
Definition at line 257 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 189 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 186 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 95 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 146 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 163 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 120 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 207 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 218 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 204 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 213 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 229 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 242 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 226 of file DoublyLinkedList.h.
Definition at line 237 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 68 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 180 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 198 of file DoublyLinkedList.h.
inlinenoexcept |
Definition at line 195 of file DoublyLinkedList.h.
