Associates state (arbitrary data) with each node during partial, depth-first traversal of a tree. Then, during a later traversal of a potentially different subset of the same tree, the state previously associated with each node can be looked up. More...
#include <CesiumUtility/TreeTraversalState.h>
Public Types | |
| using | TNodeInstance |
| The instance type of the node. | |
| using | TRawNodePointer = TNodeInstance* |
| A raw pointer to a node. | |
| using | TRawConstNodePointer = const TNodeInstance* |
| A raw pointer to a const node. | |
| size_t | getNodeCountInPreviousTraversal () const |
| Gets the total number of nodes that were visited in the previous traversal. | |
| size_t | getNodeCountInCurrentTraversal () const |
| Gets the total number of nodes that have been visited so far in the current traversal. | |
| void | beginTraversal () |
| Begins a new traversal of the tree. The "current" and "previous" traversals are swapped, and then the new "current" traversal is cleared. | |
| void | beginNode (const TNodePointer &pNode) |
| Begins traversing a node in the tree. This node becomes the "current" node. | |
| TNodePointer | getCurrentNode () const noexcept |
| Gets the current node in the traversal. | |
| bool | wasCurrentNodePreviouslyTraversed () const noexcept |
| Determines if the current node was visited in the previous traversal. | |
| const TState * | previousState () const |
| Gets the state of the current node on the previous traversal. The current node is the one for which beginNode was most recently called. | |
| TState & | currentState () |
| Gets the state of the current node during the current traversal. The current node is the one for which beginNode was most recently called. | |
| const TState & | currentState () const |
| void | finishNode (const TNodePointer &pNode) |
| Ends traversal of the given node. | |
| template<typename Func> | |
| void | forEachPreviousChild (Func &&callback) const |
| Invokes a callback for each child of the current node that was traversed in the previous traversal. | |
| void | forEachPreviousDescendant (Func &&callback) const |
| Invokes a callback for each descendant (children, grandchildren, etc.) of the current node that was traversed in the previous traversal. | |
| void | forEachCurrentDescendant (Func &&callback) |
| Invokes a callback for each descendant (children, grandchildren, etc.) of the current node that has been traversed so far in the current traversal. | |
| std::unordered_map< TRawConstNodePointer, TState > | slowlyGetCurrentStates () const |
| Gets a mapping of nodes to states for the current traversal. | |
| std::unordered_map< TRawConstNodePointer, TState > | slowlyGetPreviousStates () const |
| Gets a mapping of nodes to states for the previous traversal. | |
In order to operate efficiently, this class makes some assumptions. Violation of these assumptions can lead to undefined behavior.
| TNodePointer | The type of each node in the tree. |
| TState | The state to associate with each node. |
Definition at line 39 of file TreeTraversalState.h.
| using CesiumUtility::TreeTraversalState< TNodePointer, TState >::TNodeInstance |
Definition at line 44 of file TreeTraversalState.h.
| using CesiumUtility::TreeTraversalState< TNodePointer, TState >::TRawConstNodePointer = const TNodeInstance* |
Definition at line 55 of file TreeTraversalState.h.
| using CesiumUtility::TreeTraversalState< TNodePointer, TState >::TRawNodePointer = TNodeInstance* |
Definition at line 50 of file TreeTraversalState.h.
When beginNode is called for node A, and then for node B, without an intervening call to finishNode, that indicates that B is a child of A.
| pNode | The node traversed. |
Definition at line 95 of file TreeTraversalState.h.
Definition at line 77 of file TreeTraversalState.h.
Definition at line 167 of file TreeTraversalState.h.
Definition at line 179 of file TreeTraversalState.h.
This method must be called in the opposite order of calls to finishNode.
After finishNode, this node's parent node becomes the "current" node. previousState and currentState will return the states of this node's parent. A call to beginNode will delineate a new child of that same parent.
| pNode | The node that is done being traversed. |
Definition at line 197 of file TreeTraversalState.h.
If the current node's children were not traversed in the current traversal, this method returns without invoking the callback at all.
| Func | The type of the function to invoke. |
| callback | The function to invoke for each descendant of the current tile that has been traversed in the current traversal. The function is passed the TNodePointer and the TState. |
Definition at line 295 of file TreeTraversalState.h.
If the current node or its children were not traversed in the previous traversal, this method returns without invoking the callback at all.
| callback | The function to invoke for each previously-traversed child. The function is passed the TNodePointer and the TState. |
Definition at line 230 of file TreeTraversalState.h.
| callback | The function to invoke for each previously-traversed descendant. The function is passed the TNodePointer and the TState. |
Definition at line 263 of file TreeTraversalState.h.
inlinenoexcept |
When beginNode is called, the node passed to it becomes the current one. When finishNode is called, the parent node of the one passed to it becomes the current one.
Definition at line 128 of file TreeTraversalState.h.
Definition at line 69 of file TreeTraversalState.h.
Definition at line 61 of file TreeTraversalState.h.
nullptr if the current node was not traversed during the previous traversal. Definition at line 154 of file TreeTraversalState.h.
This is an inherently slow operation that should only be used in debug and test code.
Definition at line 321 of file TreeTraversalState.h.
Definition at line 334 of file TreeTraversalState.h.
inlinenoexcept |
Definition at line 142 of file TreeTraversalState.h.
