CesiumUtility::CreditReferencer Class Reference
Provides a way to reference a set of credits in a CreditSystem so that the references can easily be released later. More...
#include <CesiumUtility/CreditReferencer.h>
 CreditReferencer () noexcept
 Constructs a new credit referencer without a credit system.
 CreditReferencer (const std::shared_ptr< CreditSystem > &pCreditSystem) noexcept
 Constructs a new credit referencer.
 CreditReferencer (const CreditReferencer &rhs) noexcept
 Copies an instance, increasing the credit references on the CreditSystem accordingly.
 CreditReferencer (CreditReferencer &&rhs) noexcept
 Moves an instance. After the move, the rhs will not own any references, so this operation does not affect the total number of credit references on the CreditSystem.
 ~CreditReferencer () noexcept
 Destroys this instance, releasing all of its references.
CreditReferencer & operator= (const CreditReferencer &rhs) noexcept
 Copy-assigns another instance to this one. The rhs references are copied to this instance and then all credit references previously owned by this instance are released.
CreditReferencer & operator= (CreditReferencer &&rhs) noexcept
 Move-assigns another instance to this one. The rhs references are moved to this instance and then all credit references previously owned by this instance are released.
const std::shared_ptr< CreditSystem > & getCreditSystem () const noexcept
 Gets the credit system that this instance references.
void setCreditSystem (const std::shared_ptr< CreditSystem > &pCreditSystem) noexcept
 Sets the credit system that this instance references.
void addCreditReference (Credit credit) noexcept
 Adds a reference to a credit.
void releaseAllReferences () noexcept
 Releases all references that have been added to this instance.
bool isCreditReferenced (Credit credit) const noexcept
 Tests if a credit is referenced by this referencer.
Multiple CreditReferencers may be used on the same credit system to track separate sets of references – e.g., two sets of credits from different frames.
Definition at line 20 of file CreditReferencer.h.
◆ CreditReferencer() [1/4]
CesiumUtility::CreditReferencer::CreditReferencer ( )
noexcept
The methods on this instance will have no effect before the credit system is set by calling setCreditSystem.
◆ CreditReferencer() [2/4]
CesiumUtility::CreditReferencer::CreditReferencer ( const std::shared_ptr< CreditSystem > & pCreditSystem)
noexcept
pCreditSystemThe credit system that owns the referenced credits. This may be nullptr, but methods on this instance will have no effect before the credit system is set.
◆ CreditReferencer() [3/4]
CesiumUtility::CreditReferencer::CreditReferencer ( const CreditReferencer & rhs)
noexcept
rhsThe instance to copy.
◆ CreditReferencer() [4/4]
CesiumUtility::CreditReferencer::CreditReferencer ( CreditReferencer && rhs)
noexcept
rhsThe instance to move.
◆ addCreditReference()
void CesiumUtility::CreditReferencer::addCreditReference ( Credit credit)
noexcept
creditThe credit to reference.
◆ isCreditReferenced()
bool CesiumUtility::CreditReferencer::isCreditReferenced ( Credit credit) const
noexcept
creditThe credit to test if it is referenced.
◆ operator=() [1/2]
CreditReferencer & CesiumUtility::CreditReferencer::operator= ( const CreditReferencer & rhs)
noexcept
A reference to this instance.
◆ operator=() [2/2]
CreditReferencer & CesiumUtility::CreditReferencer::operator= ( CreditReferencer && rhs)
noexcept
◆ setCreditSystem()
void CesiumUtility::CreditReferencer::setCreditSystem ( const std::shared_ptr< CreditSystem > & pCreditSystem)
noexcept
If the specified credit system is different from the current one, this method will clear all current credit references.
pCreditSystemThe new credit system.
