CesiumUtility::Uri Class Referencefinal
A class for parsing and manipulating Uniform Resource Identifiers (URIs). More...
#include <CesiumUtility/Uri.h>
Public Types
typedef std::string SubstitutionCallbackSignature(const std::string &placeholder)
 A callback to fill-in a placeholder value in a URL.
 Uri (const std::string &uri)
 Attempts to create a new Uri by parsing the given string. If the string fails to parse, isValid will return false.
 Uri (const Uri &base, const std::string &relative, bool useBaseQuery=false)
 Attempts to create a new Uri from a base URI and a relative URI. If the base URI is invalid, only the relative URI string will be used. If the relative URI fails to parse, isValid will return false.
std::string_view toString () const
 Returns a string representation of the entire URI including path and query parameters.
bool isValid () const
 Returns true if this URI has been successfully parsed.
 operator bool () const
 Equivalent to isValid.
std::string_view getScheme () const
 Gets the scheme portion of the URI. If the URI was created without a scheme, this will return an empty string.
std::string_view getHost () const
 Gets the host portion of the URI. If the URI also specifies a non-default port, it will be included in the returned host. If the URI contains no host, this will return an empty string.
std::string_view getPath () const
 Gets the path portion of the URI. This will not include query parameters, if present.
std::string_view getFileName () const
 Returns the filename portion of the URI.
std::string_view getStem () const
 Returns the filename portion of the URI without any extension.
std::string_view getExtension () const
 Returns the extension portion of the URI, if present.
std::string_view getQuery () const
 Gets the query portion of the URI.
void setPath (const std::string_view &path)
 Sets the path portion of a URI to a new value. The other portions of the URI are left unmodified, including any query parameters.
void setQuery (const std::string_view &queryString)
 Sets the query portion of a URI to a new value. The other portions of the URI are left unmodified.
void ensureTrailingSlash ()
 Ensures that the Uri's path ends with a slash, modifying itself if necessary. Useful when the Uri is used as a base URL.
static std::string resolve (const std::string &base, const std::string &relative, bool useBaseQuery=false, bool assumeHttpsDefault=true)
 Attempts to resolve a relative URI using a base URI.
static std::string addQuery (const std::string &uri, const std::string &key, const std::string &value)
 Adds the given key and value to the query string of a URI. For example, addQuery("https://api.cesium.com/v1/example", "key", "value") would produce the URL https://api.cesium.com/v1/example?key=value.
static std::string getQueryValue (const std::string &uri, const std::string &key)
 Obtains the value of the given key from the query string of the URI, if possible.
static std::string substituteTemplateParameters (const std::string &templateUri, const std::function< SubstitutionCallbackSignature > &substitutionCallback)
 Substitutes the placeholders in a templated URI with their appropriate values obtained using a specified callback function.
static std::string escape (const std::string &s)
 Escapes a portion of a URI, percent-encoding disallowed characters.
static std::string unescape (const std::string &s)
 Unescapes a portion of a URI, decoding any percent-encoded characters.
static std::string unixPathToUriPath (const std::string &unixPath)
 Converts a Unix file system path to a string suitable for use as the path portion of a URI. Characters that are not allowed in the path portion of a URI are percent-encoded as necessary.
static std::string windowsPathToUriPath (const std::string &windowsPath)
 Converts a Windows file system path to a string suitable for use as the path portion of a URI. Characters that are not allowed in the path portion of a URI are percent-encoded as necessary.
static std::string nativePathToUriPath (const std::string &nativePath)
 Converts a file system path on the current system to a string suitable for use as the path portion of a URI. Characters that are not allowed in the path portion of a URI are percent-encoded as necessary.
static std::string uriPathToUnixPath (const std::string &uriPath)
 Converts the path portion of a URI to a Unix file system path. Percent-encoded characters in the URI are decoded.
static std::string uriPathToWindowsPath (const std::string &uriPath)
 Converts the path portion of a URI to a Windows file system path. Percent-encoded characters in the URI are decoded.
static std::string uriPathToNativePath (const std::string &uriPath)
 Converts the path portion of a URI to a file system path on the current system. Percent-encoded characters in the URI are decoded.
static std::string getPath (const std::string &uri)
 Gets the path portion of the URI. This will not include path parameters, if present.
static std::string setPath (const std::string &uri, const std::string &newPath)
 Sets the path portion of a URI to a new value. The other portions of the URI are left unmodified, including any path parameters.
The URI parser supports the WhatWG URL specification. It also supports protocol-relative URIs such as //example.com, and opaque paths such as a/b/c.
Definition at line 22 of file Uri.h.
Member Typedef Documentation
◆ SubstitutionCallbackSignature
typedef std::string CesiumUtility::Uri::SubstitutionCallbackSignature(const std::string &placeholder)
placeholderThe text of the placeholder. For example, if the placeholder was {example}, the value of placeholder will be example.
The value to use in place of the placeholder.
Definition at line 214 of file Uri.h.
◆ Uri() [1/2]
CesiumUtility::Uri::Uri ( const std::string & uri)
uriA string containing the URI to attempt to parse.
◆ Uri() [2/2]
CesiumUtility::Uri::Uri ( const Uri & base,
const std::string & relative,
bool useBaseQuery = false )
baseThe base URI that the relative URI is relative to.
relativeA string containing a relative URI to attempt to parse.
useBaseQueryIf true, the resulting URI will include the query parameters of both the base URI and the relative URI. If false, only the relative URI's query parameters will be used (if any).
◆ addQuery()
static std::string CesiumUtility::Uri::addQuery ( const std::string & uri,
const std::string & key,
const std::string & value )
static
uriThe URI whose query string will be modified.
keyThe key to be added to the query string.
valueThe value to be added to the query string.
The modified URI including the new query string parameter.
Deprecated
Use the UriQuery class:
Uri parsedUri(uri);
UriQuery params(parsedUri);
params.setValue(key, value);
parsedUri.setQuery(params.toQueryString());
A class for parsing and manipulating the query string of a URI.
Definition Uri.h:373
Uri(const std::string &uri)
Attempts to create a new Uri by parsing the given string. If the string fails to parse,...
◆ escape()
static std::string CesiumUtility::Uri::escape ( const std::string & s)
static
sThe string to escape.
The escaped string.
◆ getExtension()
std::string_view CesiumUtility::Uri::getExtension ( ) const
For example, for the URI http://example.com/file.txt, this will return .txt.
The extension, or empty string if the URI could not be parsed.
◆ getFileName()
std::string_view CesiumUtility::Uri::getFileName ( ) const
For example, for the URI http://example.com/file.txt, this will return file.txt.
The filename, or empty string if the URI could not be parsed.
◆ getHost()
std::string_view CesiumUtility::Uri::getHost ( ) const
The host, or an empty string if the URI could not be parsed or has no host.
◆ getPath() [1/2]
std::string_view CesiumUtility::Uri::getPath ( ) const
The path, or empty string if the URI could not be parsed.
◆ getPath() [2/2]
static std::string CesiumUtility::Uri::getPath ( const std::string & uri)
static
uriThe URI from which to get the path.
Deprecated
Create a Uri instance and use Uri::getPath() instead.
◆ getQuery()
std::string_view CesiumUtility::Uri::getQuery ( ) const
◆ getQueryValue()
static std::string CesiumUtility::Uri::getQueryValue ( const std::string & uri,
const std::string & key )
static
If the URI can't be parsed, or the key doesn't exist in the query string, an empty string will be returned.
uriThe URI with a query string to obtain a value from.
keyThe key whose value will be obtained from the URI, if possible.
The value of the given key in the query string, or an empty string if not found.
Deprecated
Uri parsedUri(uri);
params.getValue(key);
◆ getScheme()
std::string_view CesiumUtility::Uri::getScheme ( ) const
The scheme, or an empty string if the URI could not be parsed or has no scheme.
◆ getStem()
std::string_view CesiumUtility::Uri::getStem ( ) const
The stem, or empty string if the URI could not be parsed.
◆ nativePathToUriPath()
static std::string CesiumUtility::Uri::nativePathToUriPath ( const std::string & nativePath)
static
If the _WIN32 preprocessor definition is defined when compiling cesium-native, this is assumed to be a Windows-like system and this function calls windowsPathToUriPath. Otherwise, this is assumed to be a Unix-like system and this function calls unixPathToUriPath.
nativePathThe file system path.
The URI path.
◆ operator bool()
CesiumUtility::Uri::operator bool ( ) const
Definition at line 58 of file Uri.h.
◆ resolve()
static std::string CesiumUtility::Uri::resolve ( const std::string & base,
bool useBaseQuery = false,
bool assumeHttpsDefault = true )
static
For example, a relative URI /v1/example together with the base URI https://api.cesium.com would resolve to https://api.cesium.com/v1/example.
relativeThe relative URI to be resolved against the base URI.
useBaseQueryIf true, any query parameters of the base URI will be retained in the resolved URI.
assumeHttpsDefaultThis parameter is ignored and is only kept for API compatibility.
The resolved URI.
Deprecated
Use the Uri constructor instead.
◆ setPath() [1/2]
static std::string CesiumUtility::Uri::setPath ( const std::string & uri,
const std::string & newPath )
static
uriThe URI for which to set the path.
newPathThe new path portion of the URI.
The new URI after setting the path. If the original URI cannot be parsed, it is returned unmodified.
Deprecated
Create a Uri instance and use Uri::setPath(const std::string_view&) instead.
◆ setPath() [2/2]
void CesiumUtility::Uri::setPath ( const std::string_view & path)
pathThe new path portion of the URI.
◆ setQuery()
void CesiumUtility::Uri::setQuery ( const std::string_view & queryString)
queryStringThe new query portion of the URI.
◆ substituteTemplateParameters()
static std::string CesiumUtility::Uri::substituteTemplateParameters ( const std::string & templateUri,
const std::function< SubstitutionCallbackSignature > & substitutionCallback )
static
A templated URI has placeholders in the form of {name}. For example, https://example.com/{x}/{y}/{z} has three placeholders, x, y, and z. The callback will be called for each placeholder and they will be replaced with the return value of this callback.
templateUriThe templated URI whose placeholders will be substituted by this method.
substitutionCallbackThe callback that will be called for each placeholder in the provided URI. See SubstitutionCallbackSignature.
◆ unescape()
static std::string CesiumUtility::Uri::unescape ( const std::string & s)
static
sThe string to unescape.
The unescaped string.
◆ unixPathToUriPath()
static std::string CesiumUtility::Uri::unixPathToUriPath ( const std::string & unixPath)
static
If the path is absolute (it starts with a slash), then the URI will start with a slash as well.
unixPathThe file system path.
The URI path.
◆ uriPathToNativePath()
static std::string CesiumUtility::Uri::uriPathToNativePath ( const std::string & uriPath)
static
If the _WIN32 preprocessor definition is defined when compiling cesium-native, this is assumed to be a Windows-like system and this function calls uriPathToWindowsPath. Otherwise, this is assumed to be a Unix-like system and this function calls uriPathToUnixPath.
uriPathThe URI path.
◆ uriPathToUnixPath()
static std::string CesiumUtility::Uri::uriPathToUnixPath ( const std::string & uriPath)
static
If the URI path is absolute (it starts with a slash), then the file system path will start with a slash as well.
◆ uriPathToWindowsPath()
static std::string CesiumUtility::Uri::uriPathToWindowsPath ( const std::string & uriPath)
static
If the URI path is absolute (it starts with a slash), then the file system path will start with a slash or a drive letter.
◆ windowsPathToUriPath()
static std::string CesiumUtility::Uri::windowsPathToUriPath ( const std::string & windowsPath)
static
Either / or \ may be used as a path separator on input, but the output will contain only /.
If the path is absolute (it starts with a slash or with C:\ or similar), then the URI will start with a slash well.
windowsPathThe file system path.
The URI path.
