CesiumUtility::CreditSystem Class Referencefinal
Creates and manages Credit objects. Avoids repetitions and tracks which credits should be shown and which credits should be removed this frame. More...
#include <CesiumUtility/CreditSystem.h>
 CreditSystem () noexcept=default
 CreditSystem (const CreditSystem &)=delete
CreditSystem & operator= (const CreditSystem &)=delete
Credit createCredit (const CreditSource &source, std::string &&html, bool showOnScreen=false)
 Inserts a credit string.
Credit createCredit (const CreditSource &source, const std::string &html, bool showOnScreen=false)
Credit createCredit (std::string &&html, bool showOnScreen=false)
 Inserts a credit string associated with the getDefaultCreditSource.
Credit createCredit (const std::string &html, bool showOnScreen=false)
bool shouldBeShownOnScreen (Credit credit) const noexcept
 Gets whether or not the credit should be shown on screen.
void setShowOnScreen (Credit credit, bool showOnScreen) noexcept
 Sets whether or not the credit should be shown on screen.
const std::string & getHtml (Credit credit) const noexcept
 Get the HTML string for this credit.
const CreditSource * getCreditSource (Credit credit) const noexcept
 Gets the source of this credit.
bool addCreditReference (Credit credit)
 Adds a reference to a credit, incrementing its reference count. The referenced credit will be shown until its reference count goes back down to zero.
bool removeCreditReference (Credit credit)
 Removes a reference from a credit, decrementing its reference count. When the reference count goes to zero, this credit will no longer be shown.
const CreditsSnapshot & getSnapshot (CreditFilteringMode filteringMode=CreditFilteringMode::UniqueHtml) noexcept
 Gets a snapshot of the credits. The returned instance is only valid until the next call to this method.
const CreditSource & getDefaultCreditSource () const noexcept
 Gets the default credit source used when no other source is specified.
Friends
class CreditReferencer
class CreditSource
Definition at line 155 of file CreditSystem.h.
◆ addCreditReference()
bool CesiumUtility::CreditSystem::addCreditReference ( Credit credit)
creditThe credit to reference.
true if the credit was valid and the reference was added. false if the credit was created by a CreditSource that has been destroyed and so the reference could not be added.
◆ createCredit() [1/4]
Credit CesiumUtility::CreditSystem::createCredit ( const CreditSource & source,
const std::string & html,
bool showOnScreen = false )
sourceThe source of the credit. This should be an instance created and owned by a tileset, raster overlay, or other data source.
htmlThe HTML string for the credit.
showOnScreenWhether or not the credit should be shown on screen. Credits not shown on the screen should be shown in a separate popup window.
If this string already exists from the same source, returns a Credit handle to the existing entry. Otherwise returns a Credit handle to a new entry.
◆ createCredit() [2/4]
std::string && html,
◆ createCredit() [3/4]
Credit CesiumUtility::CreditSystem::createCredit ( const std::string & html,
If this string already exists, returns a Credit handle to the existing entry. Otherwise returns a Credit handle to a new entry.
Deprecated
Use the overload that takes a CreditSource.
◆ createCredit() [4/4]
Credit CesiumUtility::CreditSystem::createCredit ( std::string && html,
Deprecated
◆ getCreditSource()
const CreditSource * CesiumUtility::CreditSystem::getCreditSource ( Credit credit) const
noexcept
The source of this credit, or nullptr if the credit is invalid or was created by a CreditSource that has been destroyed.
◆ getDefaultCreditSource()
const CreditSource & CesiumUtility::CreditSystem::getDefaultCreditSource ( ) const
noexcept
Deprecated
Instead of using the default, create a CreditSource instance for each tileset, raster overlay, or other data source.
◆ getSnapshot()
const CreditsSnapshot & CesiumUtility::CreditSystem::getSnapshot ( CreditFilteringMode filteringMode = CreditFilteringMode::UniqueHtml)
noexcept
The snapshot will include a sorted list of credits that are currently active, as well as a list of credits that have been removed since the last snapshot.
filteringModeSpecifies how multiple credits with the same HTML string should be reported in the snapshot.
◆ removeCreditReference()
bool CesiumUtility::CreditSystem::removeCreditReference ( Credit credit)
creditThe credit from which to remove a reference.
true if the credit was valid and the reference was removed. false if the credit was created by a CreditSource that has been destroyed and so the reference could not be removed.
◆ CreditReferencer
friend class CreditReferencer
friend
Definition at line 329 of file CreditSystem.h.
◆ CreditSource
friend class CreditSource
friend
Definition at line 330 of file CreditSystem.h.
