CesiumUtility::Math Class Referencefinal
Mathematical constants and functions. More...
#include <CesiumUtility/Math.h>
template<glm::length_t L, typename T, glm::qualifier Q>
static constexpr glm::vec< L, T, Q > relativeEpsilonToAbsolute (const glm::vec< L, T, Q > &a, const glm::vec< L, T, Q > &b, double relativeEpsilon) noexcept
 Converts a relative to an absolute epsilon, for the epsilon-equality check between two values.
static constexpr double relativeEpsilonToAbsolute (double a, double b, double relativeEpsilon) noexcept
static bool constexpr equalsEpsilon (const glm::vec< L, T, Q > &left, const glm::vec< L, T, Q > &right, double relativeEpsilon) noexcept
 Checks whether two values are equal up to a given relative epsilon.
static constexpr bool equalsEpsilon (double left, double right, double relativeEpsilon) noexcept
static constexpr bool equalsEpsilon (double left, double right, double relativeEpsilon, double absoluteEpsilon) noexcept
 Determines if two values are equal using an absolute or relative tolerance test.
static constexpr bool equalsEpsilon (const glm::vec< L, T, Q > &left, const glm::vec< L, T, Q > &right, double relativeEpsilon, double absoluteEpsilon) noexcept
template<typename T, glm::qualifier Q>
static constexpr bool equalsEpsilon (const glm::mat< 4, 4, T, Q > &left, const glm::mat< 4, 4, T, Q > &right, double relativeEpsilon, double absoluteEpsilon) noexcept
static constexpr double sign (double value) noexcept
 Returns the sign of the value.
static constexpr double signNotZero (double value) noexcept
 Returns 1.0 if the given value is positive or zero, and -1.0 if it is negative.
static double negativePiToPi (double angle) noexcept
 Produces an angle in the range -Pi <= angle <= Pi which is equivalent to the provided angle.
static double zeroToTwoPi (double angle) noexcept
 Produces an angle in the range 0 <= angle <= 2Pi which is equivalent to the provided angle.
static double mod (double m, double n) noexcept
 The modulo operation that also works for negative dividends.
static constexpr double degreesToRadians (double angleDegrees) noexcept
 Converts degrees to radians.
static constexpr double radiansToDegrees (double angleRadians) noexcept
 Converts radians to degrees.
static double lerp (double p, double q, double time) noexcept
 Computes the linear interpolation of two values.
static constexpr double clamp (double value, double min, double max) noexcept
 Constrain a value to lie between two values.
static double toSNorm (double value, double rangeMaximum=255.0) noexcept
 Converts a scalar value in the range [-1.0, 1.0] to a SNORM in the range [0, rangeMaximum].
static constexpr double fromSNorm (double value, double rangeMaximum=255.0) noexcept
 Converts a SNORM value in the range [0, rangeMaximum] to a scalar in the range [-1.0, 1.0].
static double convertLongitudeRange (double angle) noexcept
static double roundUp (double value, double tolerance) noexcept
 Rounds a value up to the nearest integer, like ceil, except that if the value is very close to the lower integer it is rounded down (like floor) instead.
static double roundDown (double value, double tolerance) noexcept
 Rounds a value down to the nearest integer, like floor, except that if the value is very close to the higher integer it is rounded up (like ceil) instead.
static constexpr double Epsilon1 = 1e-1
 0.1
static constexpr double Epsilon2 = 1e-2
 0.01
static constexpr double Epsilon3 = 1e-3
 0.001
static constexpr double Epsilon4 = 1e-4
 0.0001
static constexpr double Epsilon5 = 1e-5
 0.00001
static constexpr double Epsilon6 = 1e-6
 0.000001
static constexpr double Epsilon7 = 1e-7
 0.0000001
static constexpr double Epsilon8 = 1e-8
 0.00000001
static constexpr double Epsilon9 = 1e-9
 0.000000001
static constexpr double Epsilon10 = 1e-10
 0.0000000001
static constexpr double Epsilon11 = 1e-11
 0.00000000001
static constexpr double Epsilon12 = 1e-12
 0.000000000001
static constexpr double Epsilon13 = 1e-13
 0.0000000000001
static constexpr double Epsilon14 = 1e-14
 0.00000000000001
static constexpr double Epsilon15 = 1e-15
 0.000000000000001
static constexpr double Epsilon16 = 1e-16
 0.0000000000000001
static constexpr double Epsilon17 = 1e-17
 0.00000000000000001
static constexpr double Epsilon18 = 1e-18
 0.000000000000000001
static constexpr double Epsilon19 = 1e-19
 0.0000000000000000001
static constexpr double Epsilon20 = 1e-20
 0.00000000000000000001
static constexpr double Epsilon21 = 1e-21
 0.000000000000000000001
static constexpr double OnePi = 3.14159265358979323846
 Pi.
static constexpr double TwoPi = OnePi * 2.0
 Two times pi.
static constexpr double PiOverTwo = OnePi / 2.0
 Pi divided by two.
static constexpr double PiOverFour = OnePi / 4.0
 Pi divided by four.
static constexpr double GoldenRatio = 1.61803398874989484
 The golden ratio, (1.0 + sqrt(5.0)) / 2.0.
Definition at line 13 of file Math.h.
◆ clamp()
static constexpr double CesiumUtility::Math::clamp ( double value,
double min,
double max )
inlinestaticconstexprnoexcept
valueThe value to constrain.
minThe minimum value.
maxThe maximum value.
The value clamped so that min <= value <= max.
Definition at line 403 of file Math.h.
◆ convertLongitudeRange()
static double CesiumUtility::Math::convertLongitudeRange ( double angle)
inlinestaticnoexcept
Converts a longitude value, in radians, to the range [-Math::OnePi, Math::OnePi).
angleThe longitude value, in radians, to convert to the range [-Math::OnePi, Math::OnePi).
The equivalent longitude value in the range [-Math::OnePi, Math::OnePi).
// Convert 270 degrees to -90 degrees longitude
Definition at line 447 of file Math.h.
◆ degreesToRadians()
static constexpr double CesiumUtility::Math::degreesToRadians ( double angleDegrees)
angleDegreesThe angle to convert in degrees.
The corresponding angle in radians.
Definition at line 367 of file Math.h.
◆ equalsEpsilon() [1/5]
static constexpr bool CesiumUtility::Math::equalsEpsilon ( const glm::mat< 4, 4, T, Q > & left,
const glm::mat< 4, 4, T, Q > & right,
double absoluteEpsilon )
This is useful to avoid problems due to roundoff error when comparing floating-point values directly. The values are first compared using an absolute tolerance test. If that fails, a relative tolerance test is performed. Use this test if you are unsure of the magnitudes of left and right.
Template Parameters
Tvalue value type.
QThe GLM qualifier type.
leftThe first value to compare.
rightThe other value to compare.
relativeEpsilonThe maximum inclusive delta between left and right for the relative tolerance test.
absoluteEpsilonThe maximum inclusive delta between left and right for the absolute tolerance test.
true if the values are equal within the epsilon; otherwise, false.
Definition at line 265 of file Math.h.
◆ equalsEpsilon() [2/5]
static bool constexpr CesiumUtility::Math::equalsEpsilon ( const glm::vec< L, T, Q > & left,
const glm::vec< L, T, Q > & right,
double relativeEpsilon )
Template Parameters
LThe length type.
Tvalue value type.
leftThe first value.
rightThe second value.
relativeEpsilonThe relative epsilon.
Whether the values are epsilon-equal
Definition at line 153 of file Math.h.
◆ equalsEpsilon() [3/5]
static constexpr bool CesiumUtility::Math::equalsEpsilon ( const glm::vec< L, T, Q > & left,
Template Parameters
LThe length type.
Tvalue value type.
Definition at line 228 of file Math.h.
◆ equalsEpsilon() [4/5]
static constexpr bool CesiumUtility::Math::equalsEpsilon ( double left,
double right,
Definition at line 169 of file Math.h.
◆ equalsEpsilon() [5/5]
double right,
0.0,
0.01,
0.0,
0.1,
3699175.1634344,
3699175.2,
3699175.1634344,
3699175.2,
Definition at line 194 of file Math.h.
◆ fromSNorm()
static constexpr double CesiumUtility::Math::fromSNorm ( double value,
double rangeMaximum = 255.0 )
valueSNORM value in the range [0, rangeMaximum].
rangeMaximumThe maximum value in the SNORM range, 255 by default.
Scalar in the range [-1.0, 1.0].
See also
Math::toSNorm
Definition at line 432 of file Math.h.
◆ lerp()
static double CesiumUtility::Math::lerp ( double p,
double q,
double time )
pThe start value to interpolate.
qThe end value to interpolate.
timeThe time of interpolation generally in the range [0.0, 1.0].
The linearly interpolated value.
double n = CesiumUtility::Math::lerp(0.0, 2.0, 0.5); // returns 1.0
Definition at line 391 of file Math.h.
◆ mod()
static double CesiumUtility::Math::mod ( double m,
double n )
mThe dividend.
nThe divisor.
The remainder.
Definition at line 352 of file Math.h.
◆ negativePiToPi()
static double CesiumUtility::Math::negativePiToPi ( double angle)
angleThe angle in radians.
The angle in the range [-Math::OnePi, Math::OnePi].
Definition at line 316 of file Math.h.
◆ radiansToDegrees()
static constexpr double CesiumUtility::Math::radiansToDegrees ( double angleRadians)
angleRadiansThe angle to convert in radians.
The corresponding angle in degrees.
Definition at line 377 of file Math.h.
◆ relativeEpsilonToAbsolute() [1/2]
static constexpr glm::vec< L, T, Q > CesiumUtility::Math::relativeEpsilonToAbsolute ( const glm::vec< L, T, Q > & a,
const glm::vec< L, T, Q > & b,
Template Parameters
LThe length type.
Tvalue value type.
aThe first value.
bThe second value.
The absolute epsilon.
Definition at line 117 of file Math.h.
◆ relativeEpsilonToAbsolute() [2/2]
static constexpr double CesiumUtility::Math::relativeEpsilonToAbsolute ( double a,
double b,
aThe first value.
bThe second value.
Definition at line 133 of file Math.h.
◆ roundDown()
static double CesiumUtility::Math::roundDown ( double value,
double tolerance )
valueThe value to round.
toleranceThe tolerance. If the value is closer than this to the higher integer, it is rounded up instead.
The rounded value.
Definition at line 492 of file Math.h.
◆ roundUp()
static double CesiumUtility::Math::roundUp ( double value,
double tolerance )
toleranceThe tolerance. If the value is closer than this to the lower integer, it is rounded down instead.
The rounded value.
Definition at line 472 of file Math.h.
◆ sign()
static constexpr double CesiumUtility::Math::sign ( double value)
This is 1 if the value is positive, -1 if the value is negative, or 0 if the value is 0.
valueThe value to return the sign of.
The sign of value.
Definition at line 287 of file Math.h.
◆ signNotZero()
static constexpr double CesiumUtility::Math::signNotZero ( double value)
This is similar to Math::sign except that returns 1.0 instead of 0.0 when the input value is 0.0.
The sign of value.
Definition at line 305 of file Math.h.
◆ toSNorm()
static double CesiumUtility::Math::toSNorm ( double value,
valueThe scalar value in the range [-1.0, 1.0].
rangeMaximumThe maximum value in the mapped range, 255 by default.
A SNORM value, where 0 maps to -1.0 and rangeMaximum maps to 1.0.
See also
Math::fromSNorm
Definition at line 417 of file Math.h.
◆ zeroToTwoPi()
static double CesiumUtility::Math::zeroToTwoPi ( double angle)
The angle in the range [0, Math::TwoPi].
Definition at line 332 of file Math.h.
◆ Epsilon1
double CesiumUtility::Math::Epsilon1 = 1e-1
0.1
Definition at line 16 of file Math.h.
◆ Epsilon10
double CesiumUtility::Math::Epsilon10 = 1e-10
0.0000000001
Definition at line 43 of file Math.h.
◆ Epsilon11
double CesiumUtility::Math::Epsilon11 = 1e-11
0.00000000001
Definition at line 46 of file Math.h.
◆ Epsilon12
double CesiumUtility::Math::Epsilon12 = 1e-12
0.000000000001
Definition at line 49 of file Math.h.
◆ Epsilon13
double CesiumUtility::Math::Epsilon13 = 1e-13
0.0000000000001
Definition at line 52 of file Math.h.
◆ Epsilon14
double CesiumUtility::Math::Epsilon14 = 1e-14
0.00000000000001
Definition at line 55 of file Math.h.
◆ Epsilon15
double CesiumUtility::Math::Epsilon15 = 1e-15
0.000000000000001
Definition at line 58 of file Math.h.
◆ Epsilon16
double CesiumUtility::Math::Epsilon16 = 1e-16
0.0000000000000001
Definition at line 61 of file Math.h.
◆ Epsilon17
double CesiumUtility::Math::Epsilon17 = 1e-17
0.00000000000000001
Definition at line 64 of file Math.h.
◆ Epsilon18
double CesiumUtility::Math::Epsilon18 = 1e-18
Definition at line 67 of file Math.h.
◆ Epsilon19
double CesiumUtility::Math::Epsilon19 = 1e-19
Definition at line 70 of file Math.h.
◆ Epsilon2
double CesiumUtility::Math::Epsilon2 = 1e-2
0.01
Definition at line 19 of file Math.h.
◆ Epsilon20
double CesiumUtility::Math::Epsilon20 = 1e-20
Definition at line 73 of file Math.h.
◆ Epsilon21
double CesiumUtility::Math::Epsilon21 = 1e-21
Definition at line 76 of file Math.h.
◆ Epsilon3
double CesiumUtility::Math::Epsilon3 = 1e-3
0.001
Definition at line 22 of file Math.h.
◆ Epsilon4
double CesiumUtility::Math::Epsilon4 = 1e-4
0.0001
Definition at line 25 of file Math.h.
◆ Epsilon5
double CesiumUtility::Math::Epsilon5 = 1e-5
0.00001
Definition at line 28 of file Math.h.
◆ Epsilon6
double CesiumUtility::Math::Epsilon6 = 1e-6
0.000001
Definition at line 31 of file Math.h.
◆ Epsilon7
double CesiumUtility::Math::Epsilon7 = 1e-7
0.0000001
Definition at line 34 of file Math.h.
◆ Epsilon8
double CesiumUtility::Math::Epsilon8 = 1e-8
0.00000001
Definition at line 37 of file Math.h.
◆ Epsilon9
double CesiumUtility::Math::Epsilon9 = 1e-9
0.000000001
Definition at line 40 of file Math.h.
◆ GoldenRatio
double CesiumUtility::Math::GoldenRatio = 1.61803398874989484
Definition at line 101 of file Math.h.
◆ OnePi
double CesiumUtility::Math::OnePi = 3.14159265358979323846
Pi.
Definition at line 81 of file Math.h.
◆ PiOverFour
double CesiumUtility::Math::PiOverFour = OnePi / 4.0
Pi divided by four.
Definition at line 96 of file Math.h.
◆ PiOverTwo
double CesiumUtility::Math::PiOverTwo = OnePi / 2.0
Pi divided by two.
Definition at line 91 of file Math.h.
◆ TwoPi
double CesiumUtility::Math::TwoPi = OnePi * 2.0
Two times pi.
Definition at line 86 of file Math.h.
