An asset that is potentially shared between multiple objects, such as an image shared between multiple glTF models. This is intended to be the base class for such assets. More...
#include <CesiumUtility/SharedAsset.h>
| void | addReference () const noexcept |
| void | releaseReference () const noexcept |
| const IDepotOwningAsset< T > * | getDepot () const |
| Gets the shared asset depot that owns this asset, or nullptr if this asset is independent of an asset depot. | |
| IDepotOwningAsset< T > * | getDepot () |
Friends | |
| template<typename TAssetType, typename TAssetKey, typename TContext> | |
| class | CesiumAsync::SharedAssetDepot |
The lifetime of instances of this class should be managed by reference counting with IntrusivePointer.
| T | The type that is deriving from this class. For example, you should declare your class as class MyClass : public SharedAsset<MyClass> { ... }; |
A SharedAsset can be in one of three possible states:
Independent Asset An independent asset isn't affiliated with an asset depot at all. Its lifetime is controlled exclusively by IntrusivePointer / reference counting. When the asset's reference count goes to zero, it deletes itself. An independent asset's getDepot returns nullptr.
Active Depot Asset This is an asset that is owned by an asset depot and that is in use, meaning it has a reference count greater than zero. The asset depot owns the asset via an std::unique_ptr, not via adding to the reference count. So when the reference count goes to zero, only the asset depot itself still has a reference to it, so it becomes an inactive depot asset.
Inactive Depot Asset This is also an asset that is owned by the asset depot, but there are no other references to it (it has a reference count of zero). It is found in the asset depot's deletionCandidates list. When a reference to it is added, it is removed from deletionCandidates and it becomes an active depot asset.
Definition at line 55 of file SharedAsset.h.
inlinenoexcept |
Definition at line 62 of file SharedAsset.h.
Definition at line 82 of file SharedAsset.h.
Definition at line 76 of file SharedAsset.h.
inlinenoexcept |
Definition at line 70 of file SharedAsset.h.
friend |
Definition at line 159 of file SharedAsset.h.
