PropertyTexturePropertyView.h
3#include <CesiumGltf/KhrTextureTransform.h>
4#include <CesiumGltf/PropertyTextureProperty.h>
5#include <CesiumGltf/PropertyTransformations.h>
6#include <CesiumGltf/PropertyTypeTraits.h>
7#include <CesiumGltf/PropertyView.h>
8#include <CesiumGltf/Sampler.h>
9#include <CesiumGltf/TextureView.h>
10#include <CesiumImage/ImageAsset.h>
11#include <CesiumUtility/Assert.h>
12
13#include <array>
14#include <cmath>
15#include <cstdint>
16#include <optional>
17
18namespace CesiumGltf {
28public:
33 static const int ErrorInvalidPropertyTexture = 15;
34
39 static const int ErrorUnsupportedProperty = 16;
40
44 static const int ErrorInvalidTexture = 17;
45
49 static const int ErrorInvalidSampler = 18;
50
54 static const int ErrorInvalidImage = 19;
55
59 static const int ErrorEmptyImage = 20;
60
65 static const int ErrorInvalidBytesPerChannel = 21;
66
74 static const int ErrorInvalidChannels = 22;
75
82 static const int ErrorChannelsAndTypeMismatch = 23;
83};
84
92template <typename ElementType>
93ElementType assembleScalarValue(const std::span<uint8_t> bytes) noexcept {
94 if constexpr (std::is_same_v<ElementType, float>) {
95 CESIUM_ASSERT(
96 bytes.size() == sizeof(float) &&
97 "Not enough channel inputs to construct a float.");
98 uint32_t resultAsUint = 0;
99 for (size_t i = 0; i < bytes.size(); i++) {
100 resultAsUint |= static_cast<uint32_t>(bytes[i]) << i * 8;
101 }
102
103 // Reinterpret the bits as a float.
104 // We need to memcpy to avoid a "dereferencing type-punned pointer will
105 // break strict-aliasing rules" error on GCC. See:
106 // https://gist.github.com/shafik/848ae25ee209f698763cffee272a58f8#how-do-we-type-pun-correctly
107 float resultAsFloat;
108 std::memcpy(&resultAsFloat, &resultAsUint, sizeof(float));
109 return resultAsFloat;
110 }
111
113 using UintType = std::make_unsigned_t<ElementType>;
114 UintType resultAsUint = 0;
115 for (size_t i = 0; i < bytes.size(); i++) {
116 resultAsUint |=
117 static_cast<UintType>(static_cast<UintType>(bytes[i]) << i * 8);
118 }
119
120 // Reinterpret the bits with the correct signedness.
121 return *reinterpret_cast<ElementType*>(&resultAsUint);
122 }
123}
124
132template <typename ElementType>
133ElementType assembleVecNValue(const std::span<uint8_t> bytes) noexcept {
134 ElementType result = ElementType();
135
136 [[maybe_unused]] constexpr glm::length_t N =
138 using T = typename ElementType::value_type;
139
140 CESIUM_ASSERT(
141 sizeof(T) <= 2 && "Components cannot be larger than two bytes in size.");
142
143 if constexpr (std::is_same_v<T, int16_t>) {
144 CESIUM_ASSERT(
145 N == 2 && "Only vec2s can contain two-byte integer components.");
146 uint16_t x = static_cast<uint16_t>(bytes[0]) |
147 static_cast<uint16_t>(static_cast<uint16_t>(bytes[1]) << 8);
148 uint16_t y = static_cast<uint16_t>(bytes[2]) |
149 static_cast<uint16_t>(static_cast<uint16_t>(bytes[3]) << 8);
150
151 result[0] = *reinterpret_cast<int16_t*>(&x);
152 result[1] = *reinterpret_cast<int16_t*>(&y);
153 }
154
155 if constexpr (std::is_same_v<T, uint16_t>) {
156 CESIUM_ASSERT(
157 N == 2 && "Only vec2s can contain two-byte integer components.");
158 result[0] = static_cast<uint16_t>(bytes[0]) |
159 static_cast<uint16_t>(static_cast<uint16_t>(bytes[1]) << 8);
160 result[1] = static_cast<uint16_t>(bytes[2]) |
161 static_cast<uint16_t>(static_cast<uint16_t>(bytes[3]) << 8);
162 }
163
164 if constexpr (std::is_same_v<T, int8_t>) {
165 for (size_t i = 0; i < bytes.size(); i++) {
166 result[int32_t(i)] = *reinterpret_cast<const int8_t*>(&bytes[i]);
167 }
168 }
169
170 if constexpr (std::is_same_v<T, uint8_t>) {
171 for (size_t i = 0; i < bytes.size(); i++) {
172 result[int32_t(i)] = bytes[i];
173 }
174 }
175
176 return result;
177}
178
186template <typename T>
187PropertyArrayCopy<T>
188assembleArrayValue(const std::span<uint8_t> bytes) noexcept {
189 std::vector<T> result(bytes.size() / sizeof(T));
190
191 if constexpr (sizeof(T) == 2) {
192 for (size_t i = 0, b = 0; i < result.size(); i++, b += 2) {
193 using UintType = std::make_unsigned_t<T>;
194 UintType resultAsUint =
195 static_cast<UintType>(bytes[b]) |
196 static_cast<UintType>(static_cast<UintType>(bytes[b + 1]) << 8);
197 result[i] = *reinterpret_cast<T*>(&resultAsUint);
198 }
199 } else {
200 for (size_t i = 0; i < bytes.size(); i++) {
201 result[i] = *reinterpret_cast<const T*>(&bytes[i]);
202 }
203 }
204
205 return PropertyArrayCopy<T>(std::move(result));
206}
207
217template <typename ElementType>
219assembleValueFromChannels(const std::span<uint8_t> bytes) noexcept {
220 CESIUM_ASSERT(
221 bytes.size() > 0 && "Channel input must have at least one value.");
222
225 }
226
228 return assembleVecNValue<ElementType>(bytes);
229 }
230
233 bytes);
234 }
235}
236
237#pragma region Non - normalized property
238
252template <typename ElementType, bool Normalized = false>
254
264template <typename ElementType>
265class PropertyTexturePropertyView<ElementType, false>
266 : public PropertyView<ElementType, false>, public TextureView {
267public:
272 : PropertyView<ElementType, false>(),
273 TextureView(),
274 _channels(),
275 _swizzle() {}
276
285 TextureView(),
286 _channels(),
287 _swizzle() {
288 CESIUM_ASSERT(
290 "An empty property view should not be constructed with a valid status");
291 }
292
300 PropertyTexturePropertyView(const ClassProperty& classProperty) noexcept
301 : PropertyView<ElementType, false>(classProperty),
302 TextureView(),
303 _channels(),
304 _swizzle() {
306 // Don't override the status / size if something is wrong with the class
307 // property's definition.
308 return;
309 }
310
311 if (!classProperty.defaultProperty) {
312 // This constructor should only be called if the class property *has* a
313 // default value. But in the case that it does not, this property view
314 // becomes invalid.
315 this->_status =
317 return;
318 }
319
321 }
322
334 const PropertyTextureProperty& property,
335 const ClassProperty& classProperty,
336 const Sampler& sampler,
337 const CesiumImage::ImageAsset& image,
338 const TextureViewOptions& options = TextureViewOptions()) noexcept
339 : PropertyView<ElementType, false>(classProperty, property),
341 sampler,
342 image,
343 property.texCoord,
344 property.getExtension<ExtensionKhrTextureTransform>(),
345 options),
346 _channels(property.channels),
347 _swizzle() {
349 return;
350 }
351
352 switch (this->getTextureViewStatus()) {
354 break;
357 return;
360 return;
363 return;
365 this->_status =
367 return;
370 default:
372 return;
373 }
374
375 _swizzle.reserve(_channels.size());
376
377 for (size_t i = 0; i < _channels.size(); ++i) {
378 switch (_channels[i]) {
379 case 0:
380 _swizzle += "r";
381 break;
382 case 1:
383 _swizzle += "g";
384 break;
385 case 2:
386 _swizzle += "b";
387 break;
388 case 3:
389 _swizzle += "a";
390 break;
391 default:
392 CESIUM_ASSERT(
393 false && "A valid channels vector must be passed to the view.");
394 }
395 }
396 }
397
411 const PropertyTextureProperty& property,
412 const ClassProperty& classProperty,
413 const CesiumGltf::Enum* pEnumDefinition,
414 const Sampler& sampler,
415 const CesiumImage::ImageAsset& image,
416 const TextureViewOptions& options = TextureViewOptions()) noexcept
417 : PropertyView<ElementType, false>(
418 classProperty,
419 property,
420 pEnumDefinition),
422 sampler,
423 image,
424 property.texCoord,
425 property.getExtension<ExtensionKhrTextureTransform>(),
426 options),
427 _channels(property.channels),
428 _swizzle() {
430 return;
431 }
432
433 switch (this->getTextureViewStatus()) {
435 break;
438 return;
441 return;
444 return;
446 this->_status =
448 return;
451 default:
453 return;
454 }
455
456 _swizzle.reserve(_channels.size());
457
458 for (size_t i = 0; i < _channels.size(); ++i) {
459 switch (_channels[i]) {
460 case 0:
461 _swizzle += "r";
462 break;
463 case 1:
464 _swizzle += "g";
465 break;
466 case 2:
467 _swizzle += "b";
468 break;
469 case 3:
470 _swizzle += "a";
471 break;
472 default:
473 CESIUM_ASSERT(
474 false && "A valid channels vector must be passed to the view.");
475 }
476 }
477 }
478
496 std::optional<PropertyValueViewToCopy<ElementType>>
497 get(double u, double v) const noexcept {
498 if (this->_status ==
500 return propertyValueViewToCopy(this->defaultValue());
501 }
502
504
505 if (value == this->noData()) {
506 return propertyValueViewToCopy(this->defaultValue());
507 } else if constexpr (IsMetadataNumeric<ElementType>::value) {
508 return transformValue(value, this->offset(), this->scale());
509 } else if constexpr (IsMetadataNumericArray<ElementType>::value) {
510 return transformArray(
511 propertyValueCopyToView(value),
512 this->offset(),
513 this->scale());
514 } else {
515 return value;
516 }
517 }
518
532
534 getRaw(double u, double v) const noexcept {
535 CESIUM_ASSERT(
537 "Check the status() first to make sure view is valid");
538
539 std::vector<uint8_t> sample =
540 this->sampleNearestPixel(u, v, this->_channels);
541
543 std::span(sample.data(), this->_channels.size()));
544 }
545
549 const std::vector<int64_t>& getChannels() const noexcept {
550 return this->_channels;
551 }
552
556 const std::string& getSwizzle() const noexcept { return this->_swizzle; }
557
558private:
559 std::vector<int64_t> _channels;
560 std::string _swizzle;
561};
562
563#pragma endregion
564
565#pragma region Normalized property
566
574template <typename ElementType>
575class PropertyTexturePropertyView<ElementType, true>
576 : public PropertyView<ElementType, true>, public TextureView {
577private:
578 using NormalizedType = typename TypeToNormalizedType<ElementType>::type;
579
580public:
585 : PropertyView<ElementType, true>(),
586 TextureView(),
587 _channels(),
588 _swizzle() {}
589
598 TextureView(),
599 _channels(),
600 _swizzle() {
601 CESIUM_ASSERT(
603 "An empty property view should not be constructed with a valid "
604 "status");
605 }
606
616 PropertyTexturePropertyView(const ClassProperty& classProperty) noexcept
617 : PropertyView<ElementType, true>(classProperty),
618 TextureView(),
619 _channels(),
620 _swizzle() {
622 // Don't override the status / size if something is wrong with the class
623 // property's definition.
624 return;
625 }
626
627 if (!classProperty.defaultProperty) {
628 // This constructor should only be called if the class property *has* a
629 // default value. But in the case that it does not, this property view
630 // becomes invalid.
631 this->_status =
633 return;
634 }
635
637 }
638
650 const PropertyTextureProperty& property,
651 const ClassProperty& classProperty,
652 const Sampler& sampler,
653 const CesiumImage::ImageAsset& image,
654 const TextureViewOptions& options = TextureViewOptions()) noexcept
655 : PropertyView<ElementType, true>(classProperty, property),
657 sampler,
658 image,
659 property.texCoord,
660 property.getExtension<ExtensionKhrTextureTransform>(),
661 options),
662 _channels(property.channels),
663 _swizzle() {
665 return;
666 }
667
668 switch (this->getTextureViewStatus()) {
670 break;
673 return;
676 return;
679 return;
681 this->_status =
683 return;
686 default:
688 return;
689 }
690
691 _swizzle.reserve(_channels.size());
692 for (size_t i = 0; i < _channels.size(); ++i) {
693 switch (_channels[i]) {
694 case 0:
695 _swizzle += "r";
696 break;
697 case 1:
698 _swizzle += "g";
699 break;
700 case 2:
701 _swizzle += "b";
702 break;
703 case 3:
704 _swizzle += "a";
705 break;
706 default:
707 CESIUM_ASSERT(
708 false && "A valid channels vector must be passed to the view.");
709 }
710 }
711 }
712
731 std::optional<PropertyValueViewToCopy<NormalizedType>>
732 get(double u, double v) const noexcept {
733 if (this->_status ==
735 return propertyValueViewToCopy(this->defaultValue());
736 }
737
739
740 if (value == this->noData()) {
741 return propertyValueViewToCopy(this->defaultValue());
742 } else if constexpr (IsMetadataScalar<ElementType>::value) {
745 this->offset(),
746 this->scale());
747 } else if constexpr (IsMetadataVecN<ElementType>::value) {
748 constexpr glm::length_t N = ElementType::length();
749 using T = typename ElementType::value_type;
750 using NormalizedT = typename NormalizedType::value_type;
752 normalize<N, T>(value),
753 this->offset(),
754 this->scale());
755 } else if constexpr (IsMetadataArray<ElementType>::value) {
756 using ArrayElementType = typename MetadataArrayType<ElementType>::type;
759 propertyValueCopyToView(value),
760 this->offset(),
761 this->scale());
762 } else if constexpr (IsMetadataVecN<ArrayElementType>::value) {
763 constexpr glm::length_t N = ArrayElementType::length();
764 using T = typename ArrayElementType::value_type;
766 propertyValueCopyToView(value),
767 this->offset(),
768 this->scale());
769 }
770 }
771 }
772
786
788 getRaw(double u, double v) const noexcept {
789 CESIUM_ASSERT(
791 "Check the status() first to make sure view is valid");
792
793 std::vector<uint8_t> sample =
794 this->sampleNearestPixel(u, v, this->_channels);
795
797 std::span(sample.data(), this->_channels.size()));
798 }
799
803 const std::vector<int64_t>& getChannels() const noexcept {
804 return this->_channels;
805 }
806
810 const std::string& getSwizzle() const noexcept { return this->_swizzle; }
811
812private:
813 std::vector<int64_t> _channels;
814 std::string _swizzle;
815};
816#pragma endregion
817
818} // namespace CesiumGltf
A copy of an array element of a PropertyTableProperty or PropertyTextureProperty.
Indicates the status of a property texture property view.
This property view is associated with a ClassProperty of an unsupported type.
The channels of this property texture property do not provide the exact number of bytes required by t...
This property view does not have a valid image index.
The channels of this property texture property are invalid. Channels must be in the range 0-N,...
This property uses an image with multi-byte channels. Only single-byte channels are supported.
This property view does not have a valid sampler index.
This property view was initialized from an invalid PropertyTexture.
This property view does not have a valid texture index.
This property is viewing an empty image.
PropertyTexturePropertyView(const PropertyTextureProperty &property, const ClassProperty &classProperty, const CesiumGltf::Enum *pEnumDefinition, const Sampler &sampler, const CesiumImage::ImageAsset &image, const TextureViewOptions &options=TextureViewOptions()) noexcept
Construct a view of the data specified by a PropertyTextureProperty.
const std::string & getSwizzle() const noexcept
Gets this property's channels as a swizzle string.
std::optional< PropertyValueViewToCopy< ElementType > > get(double u, double v) const noexcept
Gets the value of the property for the given texture coordinates with all value transforms applied....
PropertyTexturePropertyView(PropertyViewStatusType status) noexcept
PropertyValueViewToCopy< ElementType > getRaw(double u, double v) const noexcept
Gets the raw value of the property for the given texture coordinates. The sampler's wrapping mode wil...
PropertyTexturePropertyView(const ClassProperty &classProperty) noexcept
Constructs an instance of an empty property that specifies a default value. Although this property ha...
PropertyTexturePropertyView(const PropertyTextureProperty &property, const ClassProperty &classProperty, const Sampler &sampler, const CesiumImage::ImageAsset &image, const TextureViewOptions &options=TextureViewOptions()) noexcept
PropertyTexturePropertyView() noexcept
Constructs an invalid instance for a non-existent property.
const std::vector< int64_t > & getChannels() const noexcept
Gets the channels of this property texture property.
std::optional< PropertyValueViewToCopy< NormalizedType > > get(double u, double v) const noexcept
A view of the data specified by a PropertyTextureProperty.
static const PropertyViewStatusType Valid
This property view is valid and ready to use.
static const PropertyViewStatusType ErrorNonexistentProperty
This property view is trying to view a property that does not exist.
static const PropertyViewStatusType EmptyPropertyWithDefault
This property view does not contain any data, but specifies a default value. This happens when a clas...
std::optional< ElementType > offset() const noexcept
Gets the offset to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the...
std::optional< ElementType > scale() const noexcept
Gets the scale to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the ...
std::optional< ElementType > defaultValue() const noexcept
Gets the default value to use when encountering a "no data" value or an omitted property....
PropertyViewStatusType _status
PropertyViewStatusType status() const noexcept
Gets the status of this property view, indicating whether an error occurred.
std::optional< ElementType > noData() const noexcept
Gets the "no data" value, i.e., the value representing missing data in the property wherever it appea...
PropertyView()
Constructs an empty property instance. false>noData
std::optional< NormalizedType > scale() const noexcept
Constructs an empty property instance. false>scale
PropertyView()
std::optional< NormalizedType > defaultValue() const noexcept
Constructs an empty property instance. false>defaultValue
Constructs an empty property instance. false>status
std::optional< NormalizedType > offset() const noexcept
Constructs an empty property instance. false>offset
TextureViewStatus getTextureViewStatus() const noexcept
Get the status of this texture view.
TextureView() noexcept
Constructs an empty, uninitialized texture view.
std::vector< uint8_t > sampleNearestPixel(double u, double v, const std::vector< int64_t > &channels) const noexcept
Samples the image at the specified texture coordinates using NEAREST pixel filtering,...
PropertyArrayCopy< glm::vec< N, double > > transformNormalizedVecNArray(const PropertyArrayView< glm::vec< N, T > > &value, const std::optional< PropertyArrayView< glm::vec< N, double > > > &offset, const std::optional< PropertyArrayView< glm::vec< N, double > > > &scale)
Normalizes each element of an array of vectors and transforms them by optional offset and scale facto...
ElementType assembleVecNValue(const std::span< uint8_t > bytes) noexcept
Attempts to obtain a vector value from the given span of bytes.
PropertyArrayCopy< NormalizedType > transformNormalizedArray(const PropertyArrayView< T > &value, const std::optional< PropertyArrayView< NormalizedType > > &offset, const std::optional< PropertyArrayView< NormalizedType > > &scale)
Normalizes each element of an array of values and transforms them by optional offset and scale factor...
T transformValue(const T &value, const std::optional< T > &offset, const std::optional< T > &scale)
Transforms the value by optional offset and scale factors.
double normalize(T value)
Normalizes the given value between [0, 1] if unsigned or [-1, 1] if signed, based on the type's maxim...
@ ErrorEmptyImage
This texture is viewing an empty image.
Definition TextureView.h:86
@ ErrorUninitialized
This texture view has not yet been initialized.
Definition TextureView.h:66
@ Valid
This texture view is valid and ready to use.
Definition TextureView.h:61
@ ErrorInvalidSampler
This texture view does not have a valid sampler index.
Definition TextureView.h:76
@ ErrorInvalidImage
This texture view does not have a valid image index.
Definition TextureView.h:81
@ ErrorInvalidBytesPerChannel
The image for this texture has channels that take up more than a byte. Only single-byte channels are ...
Definition TextureView.h:92
@ ErrorInvalidTexture
This texture view does not have a valid texture index.
Definition TextureView.h:71
PropertyArrayCopy< T > transformArray(const PropertyArrayView< T > &value, const std::optional< PropertyArrayView< T > > &offset, const std::optional< PropertyArrayView< T > > &scale)
Transforms each element of an array of values by optional offset and scale factors....
std::conditional_t< IsMetadataNumericArray< T >::value, PropertyArrayCopy< typename MetadataArrayType< T >::type >, T > PropertyValueViewToCopy
Transforms a property value type from a view to an equivalent type that owns the data it is viewing....
ElementType assembleScalarValue(const std::span< uint8_t > bytes) noexcept
Attempts to obtain a scalar value from the given span of bytes.
PropertyArrayCopy< T > assembleArrayValue(const std::span< uint8_t > bytes) noexcept
Attempts to obtain an array value from the given span of bytes.
PropertyValueViewToCopy< ElementType > assembleValueFromChannels(const std::span< uint8_t > bytes) noexcept
Assembles the given type from the provided channel values of sampling a texture.
int32_t PropertyViewStatusType
The type used for fields of PropertyViewStatus.
std::optional< CesiumUtility::JsonValue > defaultProperty
A default value to use when encountering a noData value or an omitted property. The value is given in...
This class is not meant to be instantiated directly. Use Enum instead.
Definition Enum.h:12
glTF extension that enables shifting and scaling UV coordinates on a per-texture basis
Check if a C++ type can be represented as an array.
Check if a C++ type can be represented as an integer property type.
Check if a C++ type can be represented as an array of numeric elements property type.
Check if a C++ type can be represented as a numeric property, i.e. a scalar / vecN / matN type.
Check if a C++ type can be represented as a scalar property type.
Check if a C++ type can be represented as a vecN type.
void type
The component type of this metadata array.
A texture containing property values.
Texture sampler properties for filtering and wrapping modes.
Definition Sampler.h:14
Describes options for constructing a view on a glTF texture.
Definition TextureView.h:18
The number of dimensions that this type contains.
Convert an integer numeric type to the corresponding representation as a double type....
A 2D image asset, including its pixel data. The image may have mipmaps, and it may be encoded in a GP...
Definition ImageAsset.h:33
