CesiumGltf::PropertyViewStatus Class Reference
Indicates the status of a property view. More...
#include <CesiumGltf/PropertyView.h>
Inheritance diagram for CesiumGltf::PropertyViewStatus:
CesiumGltf::PropertyAttributePropertyViewStatus CesiumGltf::PropertyTablePropertyViewStatus CesiumGltf::PropertyTexturePropertyViewStatus
static const PropertyViewStatusType Valid = 0
 This property view is valid and ready to use.
static const PropertyViewStatusType EmptyPropertyWithDefault = 1
 This property view does not contain any data, but specifies a default value. This happens when a class property is defined with a default value and omitted from an instance of the class's collective properties. In this case, it is not possible to retrieve the raw data from a property, but its default value will be accessible.
static const PropertyViewStatusType ErrorNonexistentProperty = 2
 This property view is trying to view a property that does not exist.
static const PropertyViewStatusType ErrorTypeMismatch = 3
 This property view's type does not match what is specified in ClassProperty::type.
static const PropertyViewStatusType ErrorComponentTypeMismatch = 4
 This property view's component type does not match what is specified in ClassProperty::componentType.
static const PropertyViewStatusType ErrorArrayTypeMismatch = 5
 This property view differs from what is specified in ClassProperty::array.
static const PropertyViewStatusType ErrorInvalidNormalization = 6
 This property says it is normalized, but it does not have an integer component type.
static const PropertyViewStatusType ErrorNormalizationMismatch = 7
 This property view's normalization differs from what is specified in ClassProperty::normalized.
static const PropertyViewStatusType ErrorInvalidOffset = 8
 The property provided an invalid offset value.
static const PropertyViewStatusType ErrorInvalidScale = 9
 The property provided an invalid scale value.
static const PropertyViewStatusType ErrorInvalidMax = 10
 The property provided an invalid maximum value.
static const PropertyViewStatusType ErrorInvalidMin = 11
 The property provided an invalid minimum value.
static const PropertyViewStatusType ErrorInvalidNoDataValue = 12
 The property provided an invalid "no data" value.
static const PropertyViewStatusType ErrorInvalidDefaultValue = 13
 The property provided an invalid default value.
static const PropertyViewStatusType ErrorInvalidEnum = 14
 The property provided an invalid enum value.
The PropertyView constructor always completes successfully. However, there may be fundamental errors with the property definition. In such cases, this enumeration provides the reason.
This is defined with a class of static consts as opposed to an enum, so that derived property view classes can extend the statuses with their own specific errors.
Definition at line 35 of file PropertyView.h.
◆ EmptyPropertyWithDefault
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::EmptyPropertyWithDefault = 1
static
Definition at line 49 of file PropertyView.h.
◆ ErrorArrayTypeMismatch
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorArrayTypeMismatch = 5
static
Definition at line 73 of file PropertyView.h.
◆ ErrorComponentTypeMismatch
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorComponentTypeMismatch = 4
static
Definition at line 67 of file PropertyView.h.
◆ ErrorInvalidDefaultValue
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorInvalidDefaultValue = 13
static
Definition at line 115 of file PropertyView.h.
◆ ErrorInvalidEnum
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorInvalidEnum = 14
static
Definition at line 120 of file PropertyView.h.
◆ ErrorInvalidMax
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorInvalidMax = 10
static
Definition at line 100 of file PropertyView.h.
◆ ErrorInvalidMin
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorInvalidMin = 11
static
Definition at line 105 of file PropertyView.h.
◆ ErrorInvalidNoDataValue
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorInvalidNoDataValue = 12
static
Definition at line 110 of file PropertyView.h.
◆ ErrorInvalidNormalization
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorInvalidNormalization = 6
static
Definition at line 79 of file PropertyView.h.
◆ ErrorInvalidOffset
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorInvalidOffset = 8
static
Definition at line 90 of file PropertyView.h.
◆ ErrorInvalidScale
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorInvalidScale = 9
static
Definition at line 95 of file PropertyView.h.
◆ ErrorNonexistentProperty
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorNonexistentProperty = 2
static
Definition at line 55 of file PropertyView.h.
◆ ErrorNormalizationMismatch
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorNormalizationMismatch = 7
static
Definition at line 85 of file PropertyView.h.
◆ ErrorTypeMismatch
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::ErrorTypeMismatch = 3
static
Definition at line 61 of file PropertyView.h.
◆ Valid
const PropertyViewStatusType CesiumGltf::PropertyViewStatus::Valid = 0
static
Definition at line 40 of file PropertyView.h.
