PropertyTextureProperty.h
6#include <CesiumGltf/TextureInfo.h>
9#include <cstdint>
10#include <optional>
11#include <vector>
12
13namespace CesiumGltf {
17struct CESIUMGLTF_API PropertyTextureProperty final : public TextureInfo {
21 static constexpr const char* TypeName = "PropertyTextureProperty";
22
29 std::vector<int64_t> channels = {0};
30
36 std::optional<CesiumUtility::JsonValue> offset;
37
43 std::optional<CesiumUtility::JsonValue> scale;
44
51 std::optional<CesiumUtility::JsonValue> max;
52
59 std::optional<CesiumUtility::JsonValue> min;
60
67 int64_t getSizeBytes() const {
68 int64_t accum = 0;
69 accum += int64_t(sizeof(PropertyTextureProperty));
70 accum += TextureInfo::getSizeBytes() - int64_t(sizeof(TextureInfo));
71 accum += int64_t(sizeof(int64_t) * this->channels.capacity());
72 return accum;
73 }
74};
75} // namespace CesiumGltf
A texture containing property values.
Minimum value present in the property values. Only applicable to SCALAR, VECN, and MATN types....
An offset to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64,...
std::vector< int64_t > channels
Texture channels containing property values, identified by index. The values may be packed into multi...
A scale to apply to property values. Only applicable when the component type is FLOAT32 or FLOAT64,...
Maximum value present in the property values. Only applicable to SCALAR, VECN, and MATN types....
Reference to a texture.
Definition TextureInfo.h:14
Definition TextureInfo.h:43
