A class property. More...
#include <CesiumGltf/ClassProperty.h>
Classes | |
| struct | ComponentType |
Known values for The datatype of the element's components. Only applicable to SCALAR, VECN, and MATN types. More... | |
| struct | Type |
| Known values for The element type. More... | |
| The name of the property, e.g. for display purposes. | |
| std::optional< std::string > | description |
| The description of the property. | |
| std::string | type = Type::SCALAR |
| The element type. | |
| std::optional< std::string > | componentType |
The datatype of the element's components. Only applicable to SCALAR, VECN, and MATN types. | |
| std::optional< std::string > | enumType |
Enum ID as declared in the enums dictionary. Required when type is ENUM. | |
| bool | array = false |
Whether the property is an array. When count is defined the property is a fixed-length array. Otherwise the property is a variable-length array. | |
| std::optional< int64_t > | count |
The number of array elements. May only be defined when array is true. | |
| bool | normalized = false |
Specifies whether integer values are normalized. Only applicable to SCALAR, VECN, and MATN types with integer component types. For unsigned integer component types, values are normalized between [0.0, 1.0]. For signed integer component types, values are normalized between [-1.0, 1.0]. For all other component types, this property must be false. | |
| std::optional< CesiumUtility::JsonValue > | offset |
An offset to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the component type is FLOAT32 or FLOAT64, or when the property is normalized. | |
| std::optional< CesiumUtility::JsonValue > | scale |
A scale to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the component type is FLOAT32 or FLOAT64, or when the property is normalized. | |
| std::optional< CesiumUtility::JsonValue > | max |
Maximum allowed value for the property. Only applicable to SCALAR, VECN, and MATN types. This is the maximum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| std::optional< CesiumUtility::JsonValue > | min |
Minimum allowed value for the property. Only applicable to SCALAR, VECN, and MATN types. This is the minimum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. | |
| bool | required = false |
If required, the property must be present in every entity conforming to the class. If not required, individual entities may include noData values, or the entire property may be omitted. As a result, noData has no effect on a required property. Client implementations may use required properties to make performance optimizations. | |
| std::optional< CesiumUtility::JsonValue > | noData |
A noData value represents missing data — also known as a sentinel value — wherever it appears. BOOLEAN properties may not specify noData values. This is given as the plain property value, without the transforms from the normalized, offset, and scale properties. Must not be defined if required is true. | |
| std::optional< CesiumUtility::JsonValue > | defaultProperty |
A default value to use when encountering a noData value or an omitted property. The value is given in its final form, taking the effect of normalized, offset, and scale properties into account. Must not be defined if required is true. | |
| std::optional< std::string > | semantic |
| An identifier that describes how this property should be interpreted. The semantic cannot be used by other properties in the class. | |
| static constexpr const char * | TypeName = "ClassProperty" |
A class property.
Definition at line 17 of file ClassProperty.h.
Definition at line 219 of file ClassProperty.h.
| bool CesiumGltf::ClassProperty::array = false |
Definition at line 133 of file ClassProperty.h.
| std::optional<std::string> CesiumGltf::ClassProperty::componentType |
Known values are defined in ComponentType.
Definition at line 120 of file ClassProperty.h.
| std::optional<int64_t> CesiumGltf::ClassProperty::count |
Definition at line 139 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> CesiumGltf::ClassProperty::defaultProperty |
Definition at line 205 of file ClassProperty.h.
| std::optional<std::string> CesiumGltf::ClassProperty::description |
Definition at line 103 of file ClassProperty.h.
| std::optional<std::string> CesiumGltf::ClassProperty::enumType |
Definition at line 126 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> CesiumGltf::ClassProperty::max |
Definition at line 171 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> CesiumGltf::ClassProperty::min |
Definition at line 179 of file ClassProperty.h.
| std::optional<std::string> CesiumGltf::ClassProperty::name |
Definition at line 98 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> CesiumGltf::ClassProperty::noData |
Definition at line 197 of file ClassProperty.h.
| bool CesiumGltf::ClassProperty::normalized = false |
Definition at line 149 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> CesiumGltf::ClassProperty::offset |
Definition at line 156 of file ClassProperty.h.
| bool CesiumGltf::ClassProperty::required = false |
Definition at line 188 of file ClassProperty.h.
| std::optional<CesiumUtility::JsonValue> CesiumGltf::ClassProperty::scale |
Definition at line 163 of file ClassProperty.h.
| std::optional<std::string> CesiumGltf::ClassProperty::semantic |
Definition at line 211 of file ClassProperty.h.
| std::string CesiumGltf::ClassProperty::type = Type::SCALAR |
Definition at line 22 of file ClassProperty.h.
